Hi Friends,
for the second day I am struggling with the setting up Timed Switches for my Irrigation (Sprinklers System).
I have Wemos D1 Mini with Tasmota 6.5.0 + 4 channels relays board.
All for relays are working correctly (with the ON - OFF options).
Now I wanted to add a timer with slider for the switches and here I am going mad!.
The issue is with the state of the switch, error:
ERROR (MainThread) [homeassistant.helpers.script] Error rendering ‘Wylacz zawor glowny’ delay template: UndefinedError: ‘None’ has no attribute ‘state’
My current configuration:
configuration.yaml:
switch:
- platform: mqtt
state_topic: "stat/wemos4/POWER1"
command_topic: "cmnd/wemos4/POWER1"
qos: 0
payload_on: "ON"
payload_off: "OFF"
payload_available: "Online"
payload_not_available: "Offline"
retain: false
slider:
input_number:
slider1:
name: Czas spryskiwaczy
initial: 10
min: 1
max: 30
step: 1
automation.yaml:
- alias: "Czas spryskiwaczy"
platform: state
entity_id: switch.glowny_zawor
to: 'on'
service: homeassistant.turn_on
entity_id: script.timed_sprinkler
scripts.yaml:
timed_sprinkler:
alias: "Ustaw czas spryskiwaczy"
sequence:
# Cancel ev. old timers
- service: script.turn_off
entity_id: script.timer_off
# Set new timer
- service: script.turn_on
timer_off:
alias: "Wylacz zawor glowny"
sequence:
- delay: '00:00:{{ states.input_slider.slider1.state | int }}'
- service: homeassistant.turn_off
I was trying to add value_template to the switch like this:
value_template: ‘{% if states.switch.glowny_zawor.state %}{{ states.switch.glowny_zawor.attributes.current_activity }}{% endif %}’
But this is not changing anything.
I was also trying with this value_template:
value_template: “{{ states(‘sensor.glowny_zawor’)|float > 0 }}”
Also I was trying to change the switch configuration, like adding:
- availability_topic: “tele/wemos4/LWT”,
- state_on , state_off options,
- any many others,
Can someone please help me with this configuration?
Much appriciated!.
Regards,
Tomasz
