Timed smart plug automation
Looking for some help to create an automation that I can active and it will then turn on my smart plug at a set time and then turn off 5 hours later. The only guidance I’ve been able to find so far is to delay the activation. Any pointers would be greatly apprecaited.
If it’s always turning on at a set time, why can’t you have another automation that shuts it off at whatever time is 5 hours later?
If you mean insert a five hour delay in the automation, this is not a good idea. Something with a timer helper? One automation with a time trigger to turn on the smart plug and start the timer, a second to turn off the plug when the timer finishes.
Maybe this Blueprint . @Blacky has some great blueprints. Look up Sensor Light blueprint as well for motion activated lighting.
Yeah that would work fine, just need to figure out how to have it turn on at a specific time then the 5 hour delay should be straight forward
That would work by the sound of it
That worked perfectly, even let my have a button card to show if it’s active; thanks
His automations have been a lifesaver for me. And he supports them so actively. I even bought him some coffees.
I’m trying to do this too but seem to be way more of a novice user than everyone else on this forum
Home Assistant is one of the most confusing things I’ve ever used in my life, so please bear with me - it’s very user unfriendly!
I’m not sure what to do still, I thought there would just be a simple “Schedule” built into my dashboard but doesn’t seem to be the case.
What is it you’re trying to do? I’m no expert and the learning curve is steep, but I have picked up loads already. Let me know what you are looking for and I’ll see if I can help
