Timeout in Downloader integration
I’d like to use Downloader to grab rendered images from Grafana on my server. Due to the rendering time taking longer than 10 seconds, the download fails.
Can a ‘timeout’ option be added to the config. options?
Thanks!
probably a little late for you but I ran into the same issue.
I’ve proposed a change to the downloader (Downloader with additional timeout attribute by blannoy · Pull Request #87107 · home-assistant/core · GitHub).
This change can also be used as a custom component until the change is accepted.
cheers
Still not merged. :unamused:
