Hey all,
I’m currently working on an integration to sync the Voice PE Timers with HomeAssistant - Therefor I want to reuse the Timer Helpers which are already integrated into HA.
Sadly I couldn’t manage to integrate them as a platform since there are missing some platform specific functions:
2025-01-05 14:47:23.826 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Testi Integration for timer
File "/workspaces/voice-timer-sync/homeassistant/config_entries.py", line 640, in __async_setup_with_context
result = await component.async_setup_entry(hass, self)
AttributeError: module 'homeassistant.components.timer' has no attribute 'async_setup_entry'
I could manually add them, but since I don’t want to mess with HA Core code I wondered if I’m missing out something.
Here is my code (really quick and dirty because of testing purposes):
init.py
"""Example Load Platform integration."""
from __future__ import annotations
from homeassistant.core import HomeAssistant, Event
from homeassistant.helpers.typing import ConfigType
import homeassistant.helpers.config_validation as cv
from homeassistant.helpers.device_registry import DeviceRegistry as dr
from homeassistant.config_entries import ConfigEntry
from homeassistant.helpers.device_registry import async_get
from homeassistant.const import Platform
DOMAIN = "testi"
PLATFORMS = [Platform.NUMBER, "timer"]
CONFIG_SCHEMA = cv.platform_only_config_schema(DOMAIN)
async def async_setup_entry(hass: HomeAssistant, entry: ConfigEntry) -> bool:
"""Set up testi from a config entry."""
device_registry = async_get(hass)
device_registry.async_get_or_create(
config_entry_id=entry.entry_id,
identifiers={(DOMAIN, "testi_main")},
name="Testi Control Panel",
manufacturer="Testi Integration",
model="Timer Controller",
# Data that you want to share with your platforms
hass.data[DOMAIN] = {"entities": entry.data.get("entities", [])}
async def handle_add_timer(event: Event):
"""Handle timer event."""
timer_id = event.data.get("id", "default_id")
timer_name = event.data.get("name", "Default Name")
hass.data[DOMAIN]["entities"].append({"id": timer_id, "name": timer_name})
hass.config_entries.async_update_entry(
entry, data={"entities": hass.data[DOMAIN]["entities"]}
hass.bus.async_listen("add_timer", handle_add_timer)
await hass.config_entries.async_forward_entry_setups(entry, PLATFORMS)
return True
async def async_unload_entry(hass: HomeAssistant, entry: ConfigEntry) -> bool:
"""Unload a config entry."""
return await hass.config_entries.async_unload_platforms(entry, PLATFORMS)
timer.py
"""Platform for timer integration."""
from homeassistant.components.timer import Timer
from homeassistant.helpers.entity_platform import AddEntitiesCallback
from homeassistant.helpers.entity import DeviceInfo
from . import DOMAIN
config_entry: ConfigEntry,
async_add_entities: AddEntitiesCallback,
) -> None:
"""Set up the timer platform."""
entity = ExampleTimer(config_entry)
async_add_entities([entity])
# Save the actual entity ID to config entry data
entities = list(config_entry.data.get("entities", []))
entities.append(entity.unique_id)
hass.config_entries.async_update_entry(config_entry, data={"entities": entities})
class ExampleTimer(Timer):
"""Representation of a Timer."""
def __init__(self, config_entry: ConfigEntry) -> None:
"""Initialize the timer."""
super().__init__({"duration": "00:00:00", "restore": True})
self._attr_unique_id = "example_timer_1"
self._attr_device_info = DeviceInfo(
@property
def name(self) -> str:
"""Return the name of the timer."""
return "Example Timer"
manifest.json
"domain": "testi",
"name": "Testi",
"codeowners": [
"@howlingcoder"
"config_flow": true,
"dependencies": [],
"documentation": "https://www.home-assistant.io/integrations/testi",
"homekit": {},
"iot_class": "local_polling",
"requirements": [],
"ssdp": [],
"zeroconf": []
- Is there maybe a way to inherit and extend this within my integration? How would I then register that as a platform in HA?
Would really appreciate any input (or ideas how can I do this better, since this is my first integration)
Have a great day!
Max
