I have an automation that triggers after 15m of me not using my PC.
It then sets it to Hibernation, but only does so after checking if I was not using my PC for 30m (to put it simply. It’s a little more complicated than that).
It just stopped working; It only triggered once, the condition of not using my PC for 30m wasn’t met and then it didn’t trigger again despite the sensor showing my PC as not in use the entire night.
Here’s an excerpt of the automation from YAML mode from the UI:
Trigger:
platform: state
entity_id:
- input_boolean.am_pc
to: "off"
for:
hours: 0
minutes: 15
seconds: 0
It triggers when the input boolean has been off for 15 minutes but the condition wont allow actions unless it has been off for 30 minutes. So the automation stops and nothing happens.
- id: '1719842756841'
alias: '(Anwesenheit) (Discord) nicht am PC: (zwischen 15 und 5 Uhr: Discord: offline
&) PC nach x Minuten in den Ruhezustand versetzen'
description: 'Bug: Ich hatte den LastActive Sensor Report Intervall in HASS.Agent
auf 5m gestellt und es hatte gespamtriggert.'
- platform: state
entity_id:
to: 'off'
for:
hours: 0
minutes: 15
seconds: 0
condition: []
- alias: je nach Temperatur nach einer bestimmten Dauer an Inaktivität (zwischen
15 & 5 Uhr Discord offline &) Pc in den Ruhezustand versetzen
choose:
- conditions:
- condition: state
entity_id: input_boolean.am_pc
state: 'off'
for:
hours: 0
minutes: 30
seconds: 0
- condition: state
entity_id: timer.es_ist_heute_heiss_2
state: idle
sequence:
- alias: 'falls es zwischen 15 und 5 Uhr ist, Discord: offline (fixt das Problem,
dass man durch Ruhezustand auf abwesend statt offline gestellt wird. da
ich nicht weiß, ob mein Discord Script von HASS Agent als PC Eingabe gesehen
wird, pack ich es hier rein)'
if:
- condition: time
after: '15:00:00'
before: 05:00:00
then:
- service: button.press
metadata: {}
data: {}
entity_id: button.ars_computer_discord_offline
- delay:
hours: 0
minutes: 0
seconds: 10
milliseconds: 0
metadata: {}
data: {}
entity_id: button.ars_computer_computer_ruhezustand
- service: input_text.set_value
metadata: {}
value: Offline
entity_id: input_text.discord_online_status
alias: 'Variable: Discord Online Status="Offline"'
alias: nicht heiß? nach 30m (falls 15-5 Uhr Discord:offline &) PC in den Ruhezustand
versetzen
- conditions:
- condition: state
state: 'off'
for:
hours: 0
minutes: 15
seconds: 0
- condition: state
state: active
sequence:
- alias: 'falls es zwischen 15 und 5 Uhr ist, Discord: offline'
if:
- condition: time
after: '15:00:00'
before: 05:00:00
then:
metadata: {}
data: {}
- delay:
hours: 0
minutes: 0
seconds: 10
milliseconds: 0
metadata: {}
data: {}
metadata: {}
value: Offline
alias: 'heiß? nach 15m (falls zwischen 15 und 23 Uhr: Discord: offline &) PC
