Timer countdown in ios notification
Hi I am new to Home assistant but understand all the basics, I want to create an automation that will when a nfc tag is scanned check if a variable (helper) is true or false. If it is false change it to true and start a timer for 45 minutes then put this countdown in a notification with the ability to cancel it or add 10 more minutes to it. Once the timer finishes I want it to send a notification saying its done. If it is true then i want to cancel the timer.
Things I need:
-Mostly just need a notification that updated every second that will display the timer
-Also the checking if the var is true is not working
Thanks in advanced, any help is great!
alias: Tag Washer is scanned
description: ""
  - platform: tag
    tag_id: 0d83934d-da32-44a4-b702-a4f623
condition: []
  - if:
      - condition: state
        entity_id: automation.tag_washer_is_scanned
        state: "off"
    then:
      - device_id: 872c2fea3eb26cc1fa8ccfa823d1
        domain: mobile_app
        type: notify
        message: Washer timer is set
        title: 40 minutes starting now
          entity_id: input_boolean.washer_timer
        data: {}
      - delay:
          hours: 0
          minutes: 40
          seconds: 0
          milliseconds: 0
      - repeat:
          sequence:
              domain: mobile_app
              type: notify
              message: Washer is done
              title: Go put it in the dryer
            - service: notify.alexa_media_alexa
                  type: tts
                message: Your laundry is done in the washer please go change it over
            - delay:
                hours: 0
                minutes: 10
                seconds: 0
                milliseconds: 0
          until:
            - condition: state
              state: "off"
    else:
      - device_id: 872c2fea3eb26cc1fa8ccfa823d16
        domain: mobile_app
        type: notify
        message: Washer timer is stopped
      - service: input_boolean.toggle
          entity_id:
            - input_boolean.washer_timer
          device_id: []
          area_id: []
        data: {}
mode: single
