How can I modify the time of a running timer depending on if it is triggered by an automation or manually by HomeKit?
Basically I want to extend the duration of a fan if it is manually triggered (aka summer time cool down ). In that case the duration is doubled.
That type of question has been asked many times. In short: Inspect the event data. You might have good info already on the state change trigger data, otherwise trigger on the underlying event itself and check the data that you receive. The event listener is a great tool for this.
EDIT: I missed that youβre asking about HomeKit specifically, but the above should still be helpful. HomeKit emits events you can check.
