I have a timer that helps countdown the next time an automation can run.
I have set the timer to last 22 minutes.
alias: Time since hot water on
description: Use to limit hot water turning back on
- platform: state
entity_id:
- switch.hot_water_socket_1
to: "on"
condition: []
- service: timer.start
metadata: {}
duration: "00:22:00"
entity_id:
- timer.hot_water_on_timer
mode: single
Since initially creating the timer, I have had to edit the duration a few times.
When I look at the corresponding helper timer settings, however, the duration does not change to match the duration set in the automation.
In the above screenshot, it does match at 22 minutes, but that’s because I manually edited it.
Is this behavior normal?
