HA 2022.2.3. (also tried in 2022.2.1)
I created a timer in the UI at /config/helpers.
There is one automation which should fire an event to start it. From the UI editor:
event: timer.lab_light_timer.start
event_data: {}
and another automation which should be triggered by timer expiry. UI editor:
platform: event
event_type: timer.lab_light_timer.finished
The automations also turn a light on an off.
I have made the timer visible in my dashboard.
- the dashboard shows that when triggered, the timer does not start, but the light turns on.
- When I start the timer from the dashboard, I can see it counting down but on expiry, the light does not turn off.
Can someone please confirm if this is an issue or if I do something wrong?
I could not find the timer code anywhere in the host’s config folder, so I deleted the timer from the UI and re-created it in configuration.yaml:
timer:
lab_light_timer:
duration: "00:01:00"
It did not make any difference.
