I have a boiler physical switch that also allow me to choose timer manually.
On HA I have a switch that when I press it automatiically start the boiler for 30 minutes.
The boiler is controller via HTTP requests.
My problem start when I start the boiler from the physical button, no matter what timer I select, once automation see that it’s on, I want to replicate this in HA and therefore I switch the switch On.
When this happen, the automation send timer request of 30 minutes again. which means that I’m always getting a 30 min timer.
Is there a way to activate button on HA for visibility but do not trigger the automation after ?
[{"id":"0de77ed859832585","type":"api-call-service","z":"addcb2c7dcc3b0d8","name":"Timer on for Visibility","server":"4e241c75.5aa224","version":5,"debugenabled":false,"domain":"timer","service":"start","areaId":[],"deviceId":[],"entityId":["timer.switcher_left"],"data":"{ \"duration\": payload.time_left} ","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1080,"y":160,"wires":[[]]},{"id":"fb9b14b15d1ebe23","type":"server-state-changed","z":"addcb2c7dcc3b0d8","name":"Switcher SW","server":"4e241c75.5aa224","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_boolean.boiler","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":150,"y":320,"wires":[["a86b5e59a51ed0fb"]]},{"id":"33138beb73524422","type":"http request","z":"addcb2c7dcc3b0d8","name":"Switcher On","method":"POST","ret":"obj","paytoqs":"ignore","url":"http://172.17.0.1:8000/switcher/turn_on?id=ace95e&ip=192.168.199.152","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"credentials":{},"x":730,"y":260,"wires":[["3f142b463f0dd78b"]]},{"id":"aa1d71c3d07acfdf","type":"change","z":"addcb2c7dcc3b0d8","name":"POST Maker","rules":[{"t":"set","p":"headersobject","pt":"msg","to":"{\"Content-Type\":\"application/json\"}","tot":"json"},{"t":"set","p":"payload","pt":"msg","to":"{\"minutes\":30}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":260,"wires":[["33138beb73524422"]]},{"id":"3f142b463f0dd78b","type":"http request","z":"addcb2c7dcc3b0d8","name":"Get Switcher Status","method":"GET","ret":"obj","paytoqs":"ignore","url":"http://172.17.0.1:8000/switcher/get_state?id=ace95e&ip=192.168.199.152","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":600,"y":160,"wires":[["98a318d5d539bdf1"]]},{"id":"a86b5e59a51ed0fb","type":"switch","z":"addcb2c7dcc3b0d8","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":370,"y":320,"wires":[["aa1d71c3d07acfdf"],["df6409eca3aeab2c","ebf55b6ddb542ad3"]]},{"id":"6786bdb51fa59269","type":"http request","z":"addcb2c7dcc3b0d8","name":"Switcher Off","method":"POST","ret":"obj","paytoqs":"ignore","url":"http://172.17.0.1:8000/switcher/turn_off?id=ace95e&ip=192.168.199.152","tls":"","persist":false,"proxy":"","authType":"","senderr":false,"x":730,"y":300,"wires":[[]]},{"id":"df6409eca3aeab2c","type":"change","z":"addcb2c7dcc3b0d8","name":"POST Maker","rules":[{"t":"set","p":"headersobject","pt":"msg","to":"{\"Content-Type\":\"application/json\"}","tot":"json"},{"t":"set","p":"payload","pt":"msg","to":"{\"minutes\":30}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":300,"wires":[["6786bdb51fa59269"]]},{"id":"98a318d5d539bdf1","type":"switch","z":"addcb2c7dcc3b0d8","name":"State","property":"payload.state","propertyType":"msg","rules":[{"t":"eq","v":"ON","vt":"str"},{"t":"eq","v":"OFF","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":810,"y":160,"wires":[["05777f7db3365c20"],["ebf55b6ddb542ad3","0373549635127469"]]},{"id":"ebf55b6ddb542ad3","type":"api-call-service","z":"addcb2c7dcc3b0d8","name":"","server":"4e241c75.5aa224","version":5,"debugenabled":false,"domain":"timer","service":"cancel","areaId":[],"deviceId":[],"entityId":["timer.switcher_left"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1050,"y":340,"wires":[[]]},{"id":"d2f12351f06cc7be","type":"api-call-service","z":"addcb2c7dcc3b0d8","name":"Turn Switcher on for Visibility","server":"4e241c75.5aa224","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_on","areaId":[],"deviceId":[],"entityId":["input_boolean.boiler"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1100,"y":220,"wires":[[]]},{"id":"0373549635127469","type":"api-call-service","z":"addcb2c7dcc3b0d8","name":"Turn Switcher on for Visibility","server":"4e241c75.5aa224","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_off","areaId":[],"deviceId":[],"entityId":["input_boolean.boiler"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1100,"y":280,"wires":[[]]},{"id":"5da11eacc2f4eadf","type":"inject","z":"addcb2c7dcc3b0d8","name":"1m","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"*/1 6-23 * * *","once":false,"onceDelay":0.1,"topic":"","x":150,"y":160,"wires":[["3f142b463f0dd78b"]]},{"id":"05777f7db3365c20","type":"junction","z":"addcb2c7dcc3b0d8","x":940,"y":160,"wires":[["0de77ed859832585","d2f12351f06cc7be"]]},{"id":"4e241c75.5aa224","type":"server","name":"Local HA","version":2,"addon":false,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30}]
