Timer offline
Hello everyone. This continues with the software of an esp32 that manages a board of 8 relays that control an aquarium. Now I would like to see how to make the esp be the one that handles the turning on and off of the lights without depending on the wifi. They helped me before with the temperature issue. Now I have a couple of questions. If I manage this on the esp side, who controls what the real time is? On the home assistant side, I have two variables of the type datetime in which I configure from the UI which is the start time and which is the shutdown time. If I want this to continue to be configured from HA, would I have to separate the hour from the minutes to be able to configure it from esphome?
Is this code ok? How do I use the two datetime variables that I use in HA?
Sin título
globals:
  - id: minutes_on
    type: int
    restore_value: yes
    initial_value: '0'
  - id: hours_on
    type: int
    restore_value: yes
    initial_value: '15'
  - id: minutes_off
    type: int
    restore_value: yes
    initial_value: '0'
  - id: hours_off
    type: int
    restore_value: yes
    initial_value: '23'
number:
    name: "set minutes on"
    optimistic: true
    min_value: 0
    max_value: 59
    step: 1
    on_value:
      - globals.set:
          value: !lambda 'return id(set_minutes_on).state;'
    name: "set hour on"
    optimistic: true
    min_value: 0
    max_value: 23
    step: 1
    on_value:
      - globals.set:
          value: !lambda 'return id(set_hours_on).state;'
    name: "set minutes off"
    optimistic: true
    min_value: 0
    max_value: 59
    step: 1
    on_value:
      - globals.set:
          value: !lambda 'return id(set_minutes_off).state;'
    name: "set hour on"
    optimistic: true
    min_value: 0
    max_value: 23
    step: 1
    on_value:
      - globals.set:
          value: !lambda 'return id(set_hours_off).state;'
time:
  - platform: sntp
    on_time:
      # Cada dia a las 15hs
      - seconds: 0
        minutes: 0 #minutes_on
        hours: 15  #hours_on
        then:
         - switch.turn_on: relay_8
      # Cada dia a las 23hs
      - seconds: 0
        minutes: 0 #minutes_off
        hours: 23   #hours_off
        then:
