Timer question in automation
I’ve creaeted an automation for my bed lights it’s as follows:
- alias: 20a - Bed Lights
  id: Bed Lights On
  initial_state: true
    - platform: sun
      event: sunset
    service: switch.turn_on
    entity_id: switch.bed_lights_2
- alias: 20b - Bed Lights Off
    - platform: state
      entity_id: binary_sensor.bed_sensor_contact_2
      to: "on"
    - service: timer.start
        entity_id: timer.out_of_bed
- alias: "Timer Reset for Bed"
  id: "Bed Reset Timer"
    - platform: state
      to: "off"
    - service: timer.cancelled
- alias: "Timerstop"
    - platform: event
      event_type: timer.finished
      event_data:
    - service: switch.turn_off
I’m getting an errror on the timer.cancelled portion…
Timer Reset for Bed uses an unknown service
The automation “Timer Reset for Bed” (automation.timer_reset_for_bed) has an action that calls an unknown service: timer.cancelled.
This error prevents the automation from running correctly. Maybe this service is no longer available, or perhaps a typo caused it.
To fix this error, [edit the automation](/config/automation/edit/Bed Reset Timer) and remove the action that calls this service.
Click on SUBMIT below to confirm you have fixed this automation.
I’m glad that HA gives me the info but perhaps I used the timer.cancelled command incorrecdtly? If so how should I use it or is tiimer.cancelled no longer working?
Thank you in advance!!
timer.cancel
is what comes up in dev tools > services.
You are right… I was not reading the timer documentation correctly. HA fires the timer.cancelled event and you call it by using timer.cancel :slight_smile:
Now it works as it should!
Thank you!!!
If you are interested, here’s how to consolidate the four automations into one.
- alias: Bed Lights
    - platform: sun
      event: sunset
    - platform: state
        - "off"
        - "on"
      to:
        - "on"
        - "off"
    - platform: event
      event_data:
  condition: []
    - if: "{{ trigger.platform == 'state' }}"
      then:
        - service: "timer.{{ iif(trigger.to_state.state == 'on', 'start', 'cancel') }}"
      else:
        - service: "switch.turn_{{ iif(trigger.platform == 'sun', 'on', 'off') }}"
I don’t think any of the three triggers can occur simultaneously so there’s probably no need to use mode: queued.
OH I’m interested!!!
Thank you so much!!
That is some VERY nice work…above my pay grade LOL
But I’ll be studying that for sure!!
:slight_smile:
In case anyone is interested here’s the finished code Thank you @123
I created 2 switches so I could put them in lovelace and show them in the frontend…
This is the automation to turn off those switches.
Created the out_of_bed timer in the helper section
- alias: 47 - Turn off door alarms
  description: ""
    - platform: state
        - "off"
        - "on"
      to:
        - "on"
        - "off"
    - platform: event
      event_data:
  condition: []
      then:
      else:
            entity_id:
              - switch.bd_alarm
              - switch.fd_alarm
