Dear All,
please help me understand what is the problem with the following setup.
The scenario is that I want to run my AC for a while after I fall asleep but not overnight.
The original plan was to create a script that starts a timer and the AC and an automation counterpart that stops the AC when the timer finishes. This is the first time I’m using the timer component so there might be problems with my understanding.
So the timer is defined like this:
timer: sleep: duration: 00:30:00
The script is set up like this:
'1527807975408': alias: Sleeping AC sequence: - data: entity_id: timer.sleep service: timer.start - data: entity_id: climate.living_room_hvac operation_mode: cool service: climate.set_operation_mode - alias: '' data: message: '{{states(''timer.sleep.remaining'')}}' notification_id: 123 title: Time Left service: persistent_notification.create
and the automation:
- id: '1527808056871' alias: Stop Sleeping AC trigger: - event_data: entity_id: timer.sleep event_type: timer.finished platform: event condition: [] action: - data: entity_id: climate.living_room_hvac operation_mode: none service: climate.set_operation_mode - data: notification_id: 123 service: persistent_notification.dismiss
I have two questions:
- the AC starts as it should but it does not stop, can you tell me what’s wrong?
- the persistent notification displays the remaining time as unknown. Any ideas why?
Thanks!!
B
