Timer remaining questions?
In yaml code, how can I get the remaining time left on an active timer without having to subtract the “finishes at” from the current time?
Why does the attribute “remaining” always just display the original duration regardless of the state of the timer?
That’s a mystery!
  • The UI shows the time remaining
  • Entity-cards (for example) do NOT show the time remaining
My solution was to use the (fantastic) custom:button-card
type: custom:button-card
entity: timer.timer_doorbell_off
show_state: true
show_icon: false
The button-card for some reason shows the “live” time remaining.
Well, that solution is great for the UI, but if we wanted to instead use the info in a notification alert, it would be handy to show the actual remaining time. How does one do that? Can I create a helper or similar to do the calculation so I can simply reference it? #NoobHere
You can use Templating.
action: notify.YOUR_NOTIFIER
  message: |
    The timer will finish in {{ time_until(state_attr('timer.YOUR_TIMER','finishes_at'), 2) }}
The time_until() function will return a string like “1 hour, 45 minutes”
