currently there is no feature to reset a timer while its paused.
you only can restart it, when the timer is “idle”
also changing the duration is also only applyed while idle.
if its paused, the current coundtown time remains and will be continued after unpaused.
so if there is an automation triggered by an finished / idle timer, you only can delay due to pausing but not by changing the timer value.
