Yes, it was. It always worked until maybe 2024.1 release; I think.
- Core 2024.3.3
- Supervisor 2024.03.1
- Operating System 12.1
- Frontend 20240307.0
I am running HAOS on the Beelink mini-PC, not on RasPI. I started out with a Mini-PC because Raspberry PI was hard to get. Glad I didn’t start with that because I am barely using the resources of this machine. Got over 100 devices, about 80 Zigbee.
Since I updated the RESTORE file in the config folder, no issues since. It just does not update my changes when
The problem
I enable “restore” when I create a Timer helper, but this option is not saved. The same behavior when I try to modify an existing Timer helper.
What version of Home Assistant Core has the issue?
Core 2024.3.3
What was the last working version of Home Assistant Core?
I did not start noticing this until February. Sometime in 2024.2.*.
What type of installation are you running?
Home Assistant OS, directly. No container.
Integration causing the issue
Timer (only in GUI)
Setting it in the config folder holds the setting.
\192.168.0.169\config.storage\timer
Link to integration documentation on our website
Diagnostics information
No response
Example YAML snippet
This is only a part of the “timer” code.
"version": 1,
"minor_version": 1,
"key": "timer",
"data": {
"items": [
"id": "ibuprofen",
"duration": "8:00:00",
"name": "Timer Ibuprofen Antonio",
"icon": "mdi:pill",
"restore": true
"id": "acetaminophen",
"name": "Timer Acetaminophen Antonio",
"duration": "4:00:00",
"icon": "mdi:pill",
"restore": true
"id": "timer_acetaminophen_serenity",
"name": "Timer Acetaminophen Serenity",
"icon": "mdi:pill",
"restore": true
Anything in the logs that might be useful for us?
Honestly, I did not see anything. When I set the timer, it shows that it is saved, but that is it. No instance of the restore. To be real honest, I may be looking in the wrong place.
Additional information
The restore timer works when changing it in the config folder. Above, it may look like it never works, just not working all the time. I would say 60%, I would check Restore? and it does not save. 40%, it works. Here is one more thing to add. If I add it for a new timer, check Restore?, that has worked 100% of the time. It does not work when editing it.
