You will need the secret custom node as I use it to store some secret items for the api.
Basically the flow just triggers from an “on” or “off” to input.boolean and then checks if other switches are “on” in a group. Either way after this it calls the Rachio api to turn on a sprinkler zone.
99% percent of the time it works as expected. Then occasionally a timer will have been started and I will see it in the gui running. After about 1 minute has counted down the timer will just stop and revert to an idle state.
[{"id":"9d931426.bb1f98","type":"tab","label":"Rachio Run Zones","disabled":false,"info":""},{"id":"3d03ef0d.036a4","type":"secret","z":"9d931426.bb1f98","name":"Bearer Token","x":970,"y":60,"wires":[["af185ff3.e58fc"]]},{"id":"af185ff3.e58fc","type":"function","z":"9d931426.bb1f98","name":"Create Bearer Token","func":"msg.headers = {\n Authorization: \"Bearer \"+ msg.secret\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1200,"y":60,"wires":[["62636235.2a91dc"]]},{"id":"a72d735f.78ec4","type":"www-request","z":"9d931426.bb1f98","name":"Get Person Info","method":"GET","ret":"obj","url":"","follow-redirects":false,"persistent-http":false,"tls":"","x":1600,"y":120,"wires":[["6265a118.12e74"]]},{"id":"9a512483.abcec8","type":"secret","z":"9d931426.bb1f98","name":"Person ID","x":960,"y":120,"wires":[["b4b186cb.1fd298"]]},{"id":"b4b186cb.1fd298","type":"change","z":"9d931426.bb1f98","name":"Create Person ID","rules":[{"t":"set","p":"personid","pt":"msg","to":"secret","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1190,"y":120,"wires":[["1c7a78b0.c673b7"]]},{"id":"1c7a78b0.c673b7","type":"template","z":"9d931426.bb1f98","name":"Set API Url","field":"url","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"https://api.rach.io/1/public/person/{{personid}}","output":"str","x":1410,"y":120,"wires":[["a72d735f.78ec4"]]},{"id":"6265a118.12e74","type":"change","z":"9d931426.bb1f98","name":"Get enabled zones from Rachio","rules":[{"t":"set","p":"zones","pt":"msg","to":"payload.devices.zones[enabled=true].{\"zoneNumber\": zoneNumber, \"id\": id}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1030,"y":220,"wires":[["fb48b425.b756e8"]]},{"id":"fb48b425.b756e8","type":"change","z":"9d931426.bb1f98","name":"Retrieve zone submitted","rules":[{"t":"set","p":"zone","pt":"msg","to":"(\t $zone := $substring(topic,-1) ~> $number;\t *[zoneNumber=$zone].id\t)\t\t","tot":"jsonata"},{"t":"set","p":"timer","pt":"msg","to":"(\t $duration := $substring(topic,-1) ~> $number;\t $duration := \"input_number.sprinkler_qrruntime_zone\" & $duration;\t)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1310,"y":220,"wires":[["3a714733.fe92b8"]]},{"id":"595cf50f.4da1ac","type":"www-request","z":"9d931426.bb1f98","name":"Call Rachio Zone Start API","method":"PUT","ret":"txt","url":"","follow-redirects":false,"persistent-http":false,"tls":"","x":1020,"y":280,"wires":[["2425213c.c98fbe"]]},{"id":"6335ad9f.a893d4","type":"change","z":"9d931426.bb1f98","name":"Set zone info","rules":[{"t":"set","p":"zonejson","pt":"msg","to":"{\t \"id\": zone,\t \"duration\": duration\t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1710,"y":220,"wires":[["f9c709fc.3c9028"]]},{"id":"f9c709fc.3c9028","type":"function","z":"9d931426.bb1f98","name":"Set values for Rachio API","func":"msg.payload = msg.zonejson;\nmsg.headers = {\n \"Authorization\": \"Bearer \"+ msg.bearer,\n \"Content-Type\": \"application/json\"\n};\nmsg.url = 'https://api.rach.io/1/public/zone/start';\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1930,"y":220,"wires":[["b0cd81f4.50162"]]},{"id":"b0cd81f4.50162","type":"change","z":"9d931426.bb1f98","name":"Remove old msg","rules":[{"t":"delete","p":"zonejson","pt":"msg"},{"t":"delete","p":"zones","pt":"msg"},{"t":"delete","p":"personid","pt":"msg"},{"t":"delete","p":"topic","pt":"msg"},{"t":"delete","p":"bearer","pt":"msg"},{"t":"delete","p":"zone","pt":"msg"},{"t":"delete","p":"secret","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":2170,"y":220,"wires":[["595cf50f.4da1ac"]]},{"id":"62636235.2a91dc","type":"change","z":"9d931426.bb1f98","name":"Create Person ID","rules":[{"t":"set","p":"bearer","pt":"msg","to":"secret","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1430,"y":60,"wires":[["9a512483.abcec8"]]},{"id":"3a714733.fe92b8","type":"function","z":"9d931426.bb1f98","name":"Round Duration","func":"const globalHomeAssistant = global.get('homeassistant');\nconst $timer = msg.timer;\nconst state = globalHomeAssistant.homeAssistant.states[$timer].state;\nconst removedDecimal = Math.round(state);\nmsg.duration = removedDecimal * 60;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1540,"y":220,"wires":[["6335ad9f.a893d4"]]},{"id":"55c1497f.b33b58","type":"api-call-service","z":"9d931426.bb1f98","name":"","server":"b9eb4c89.0f03f","version":1,"debugenabled":true,"service_domain":"timer","service":"start","entityId":"","data":"{\t \"duration\": msg.duration,\t \"entity_id\": msg.timer\t}","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1680,"y":280,"wires":[["ccdf2a96.d9fdf8"]]},{"id":"2425213c.c98fbe","type":"switch","z":"9d931426.bb1f98","name":"","property":"statusCode","propertyType":"jsonata","rules":[{"t":"eq","v":"204","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":1290,"y":280,"wires":[["41b86fc0.d41c3"]]},{"id":"476800e3.e68ca","type":"api-render-template","z":"9d931426.bb1f98","name":"Get on entity","server":"b9eb4c89.0f03f","template":"{% for entity_id in states.group.sprinkler_all_zones.attributes.entity_id -%}\n{% set domain, device = entity_id.split('.') -%}\n{% set entity = states[domain][device] %}\n{% if entity.state == \"on\" %}\n{{ entity.entity_id }}\n{% endif %}\n{% endfor %}","resultsLocation":"switch","resultsLocationType":"msg","templateLocation":"","templateLocationType":"none","x":410,"y":60,"wires":[["6b679731.8cd5c8"]]},{"id":"6b679731.8cd5c8","type":"switch","z":"9d931426.bb1f98","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":3,"x":170,"y":180,"wires":[["40988f69.8270f"],["f194687e.feae58"],[]]},{"id":"2eee57ae.966ee8","type":"api-call-service","z":"9d931426.bb1f98","name":"","server":"b9eb4c89.0f03f","version":1,"debugenabled":false,"service_domain":"input_boolean","service":"turn_off","entityId":"","data":"{\t \"entity_id\": msg.ib\t}","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":560,"y":280,"wires":[["3d03ef0d.036a4"]]},{"id":"40988f69.8270f","type":"switch","z":"9d931426.bb1f98","name":"","property":"switch","propertyType":"msg","rules":[{"t":"neq","v":"","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":570,"y":140,"wires":[["cc8ea22f.d33fc"],["3d03ef0d.036a4"]]},{"id":"cc8ea22f.d33fc","type":"function","z":"9d931426.bb1f98","name":"","func":"myswitch = msg.switch;\nlastChar = myswitch.substring(myswitch.length - 1);\nmsg.ib = \"input_boolean.sprinkler_submit_zone\" + lastChar;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":560,"y":200,"wires":[["2eee57ae.966ee8"]]},{"id":"ccdf2a96.d9fdf8","type":"debug","z":"9d931426.bb1f98","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1810,"y":500,"wires":[]},{"id":"f194687e.feae58","type":"switch","z":"9d931426.bb1f98","name":"","property":"switch","propertyType":"msg","rules":[{"t":"else"},{"t":"neq","v":"","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":330,"y":200,"wires":[[],["c4367a78.0684b8"]]},{"id":"c4367a78.0684b8","type":"function","z":"9d931426.bb1f98","name":"","func":"myswitch = msg.switch;\nlastChar = myswitch.substring(myswitch.length - 1);\nmsg.char = lastChar;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":120,"y":260,"wires":[["11f694cc.463deb"]]},{"id":"11f694cc.463deb","type":"template","z":"9d931426.bb1f98","name":"","field":"items","fieldType":"msg","format":"json","syntax":"mustache","template":"{\n \"ib\": \"input_boolean.sprinkler_submit_zone{{char}}\",\n \"switch\": \"switch.sprinkler_zone{{char}}\",\n \"timer\": \"timer.sprinkler_qr_zone{{char}}\"\n}","output":"json","x":280,"y":260,"wires":[["aac836e2.5e2e98","da4c669d.0a1ed8","cd8268c9.6a2e08"]]},{"id":"cc674132.dbcf8","type":"api-call-service","z":"9d931426.bb1f98","name":"","server":"b9eb4c89.0f03f","version":1,"debugenabled":true,"service_domain":"timer","service":"finish","entityId":"","data":"{\t \"entity_id\": msg.items.timer\t}","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":500,"y":480,"wires":[["ccdf2a96.d9fdf8"]]},{"id":"b2dafd5b.1dbae","type":"api-call-service","z":"9d931426.bb1f98","name":"","server":"b9eb4c89.0f03f","version":1,"debugenabled":false,"service_domain":"switch","service":"turn_off","entityId":"","data":"{\t \"entity_id\": msg.items.switch\t}","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":510,"y":360,"wires":[[]]},{"id":"3cda756d.b4bb0a","type":"api-call-service","z":"9d931426.bb1f98","name":"","server":"b9eb4c89.0f03f","version":1,"debugenabled":false,"service_domain":"input_boolean","service":"turn_off","entityId":"","data":"{\t \"entity_id\": msg.items.ib\t}","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":540,"y":420,"wires":[[]]},{"id":"96f7c060.fc989","type":"api-current-state","z":"9d931426.bb1f98","name":"Check entity on","server":"b9eb4c89.0f03f","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"","state_type":"str","state_location":"","override_payload":"none","entity_location":"payload","override_data":"msg","blockInputOverrides":false,"x":280,"y":400,"wires":[["b2dafd5b.1dbae"],[]]},{"id":"64834a7b.9372a4","type":"api-current-state","z":"9d931426.bb1f98","name":"Check entity on","server":"b9eb4c89.0f03f","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"","state_type":"str","state_location":"","override_payload":"none","entity_location":"payload","override_data":"msg","blockInputOverrides":false,"x":280,"y":460,"wires":[["3cda756d.b4bb0a"],[]]},{"id":"feb108a2.b17838","type":"api-current-state","z":"9d931426.bb1f98","name":"Check entity on","server":"b9eb4c89.0f03f","version":1,"outputs":2,"halt_if":"active","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"","state_type":"str","state_location":"","override_payload":"none","entity_location":"payload","override_data":"msg","blockInputOverrides":false,"x":280,"y":520,"wires":[["cc674132.dbcf8"],[]]},{"id":"aac836e2.5e2e98","type":"function","z":"9d931426.bb1f98","name":"","func":"msg.payload = {\n entity_id: msg.items.ib\n};\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":100,"y":440,"wires":[["64834a7b.9372a4"]]},{"id":"da4c669d.0a1ed8","type":"function","z":"9d931426.bb1f98","name":"","func":"msg.payload = {\n entity_id: msg.items.switch\n};\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":100,"y":400,"wires":[["96f7c060.fc989"]]},{"id":"cd8268c9.6a2e08","type":"function","z":"9d931426.bb1f98","name":"","func":"msg.payload = {\n entity_id: msg.items.timer\n};\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":100,"y":480,"wires":[["feb108a2.b17838"]]},{"id":"41b86fc0.d41c3","type":"function","z":"9d931426.bb1f98","name":"","func":"ib = msg.data.entity_id;\nlastChar = ib.substring(ib.length - 1);\nmsg.timer = \"timer.sprinkler_qr_zone\" + lastChar;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1460,"y":280,"wires":[["55c1497f.b33b58"]]},{"id":"b7aefd9d.e0a74","type":"trigger-state","z":"9d931426.bb1f98","name":"Run when clicked","server":"b9eb4c89.0f03f","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"input_boolean.sprinkler_submit_zone","entityidfiltertype":"substring","debugenabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"on","propertyValue":"new_state.state"}],"outputs":2,"customoutputs":[],"outputinitially":false,"state_type":"str","x":110,"y":40,"wires":[["476800e3.e68ca"],[]]},{"id":"6593845e.c1f0fc","type":"trigger-state","z":"9d931426.bb1f98","name":"Run when clicked","server":"b9eb4c89.0f03f","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"input_boolean.sprinkler_submit_zone","entityidfiltertype":"substring","debugenabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"off","propertyValue":"new_state.state"}],"outputs":2,"customoutputs":[],"outputinitially":false,"state_type":"str","x":110,"y":100,"wires":[["476800e3.e68ca"],[]]},{"id":"b9eb4c89.0f03f","type":"server","z":"","name":"Home Assistant","addon":true}]
