franz134
(Franz134)
May 18, 2024, 8:59am
1
I’m trying to build a sort of timed switch/relay (Zeitschaltuhr in german) depending on some sensors.
The time should be easily changeable in the frontend inside of HA, therefor my idea was to use the rather new datetime component.
Now my question is how to turn on/off the switch, if the current time (from HA) goes past one of those trigger times? I’ll probably have to use lambdas in the time component - maybe someone with more experience in this could help me.
my code snippet:
time:
- platform: homeassistant
datetime:
type: time
optimistic: yes
initial_value: "09:00:00"
restore_value: true
type: time
optimistic: yes
initial_value: "15:00:00"
restore_value: true
I think you just use the on_time
time:
datetime:
type: time
optimistic: yes
restore_value: true
time_id: ha_time
on_time:
then:
- switch.turn_on: daylamp
type: time
optimistic: yes
restore_value: true
time_id: ha_time
on_time:
then:
- switch.turn_off: daylamp
franz134
(Franz134)
May 18, 2024, 11:45am
3
This might probably be correct, but how do I refer/point to the value/timestamp stored in the datetime component?
My problem is mainly to find a working syntax
Edit: I saw you used on_time
in datetime
- this is not possible, its just possible in time
Then either something is broken or the docs are wrong:
franz134
(Franz134)
May 18, 2024, 1:26pm
5
This is my working code so far if someone want to take a look…
but I don’t want to recompile it if I need to change the time
# VARIABLES #################################
datetime:
type: time
optimistic: yes
restore_value: true
type: time
optimistic: yes
restore_value: true
number:
optimistic: true
restore_value: true
initial_value: 30
min_value: 20
max_value: 40
step: 1
# SENSOR ##################################
dallas:
- pin: GPIO27
- platform: dallas
address: 0xec63bd451f64ff28
on_value:
then:
- lambda: |-
if (id(temp_day).state > id(temp_thr_day).state) {
id(lamp).turn_off();
- lambda: |-
if (id(temp_day).state < id(temp_thr_day).state && id(lamp_time).state) {
id(lamp).turn_on();
time:
on_time: # 9 to 15 o'clock
- cron: '0 0 9 * * *'
then:
if:
condition:
- switch.is_on: heating_mode
then:
- switch.turn_on: lamp_time
- cron: '0 0 15 * * *'
then:
- switch.turn_off: lamp_time
switch:
optimistic: true
restore_mode: RESTORE_DEFAULT_ON
- platform: template # helper
name: "Heizzeit Heizlampe"
#internal: True
optimistic: true
restore_mode: RESTORE_DEFAULT_OFF
on_turn_on:
then:
- lambda: |-
if (id(temp_day).state < id(temp_thr_day).state) {
id(lamp).turn_on();
on_turn_off:
then:
# OUTPUT #############################
- platform: gpio
pin: GPIO32
I missed it on the first look, but your datetime
entries are missing time_id
… I’ll correct it in my post above.
franz134
(Franz134)
May 18, 2024, 1:55pm
7
Didgeridrew:
missing time_id
this is in my case automatically set to ha_time
because I only have one time component
I just tested it… compile fails if time_id
isn’t set explicitly when using on_time
. With explicit time_id
it compiles and functions.
franz134
(Franz134)
May 18, 2024, 2:38pm
9
It works, thanks mate
But for my liking the documentation should be edited in this case, because the on_time
mention is not really listed as an automation trigger at datetime (and also no mention that therefore time_id
must be set)
Time_id is a required configuration setting and its explicitly stated as such in the documentation.
time_id (Required, ID): The ID of the time entity. Automatically set to the ID of a time component if only a single one is defined
