i need to create an on/off timer for a plug that is at 1:05h when a battery entity is at 27% and then adds 5 minutes for every 2% more the battery loses (for example 25% = 1:10h 23% = 1:15h 21%= 1:20 and so on) i can’t do a normal battery charge automation because the device is not on when charging so only the last state is known
Starting the timer would need a templated action like:
service: timer.start
duration: |
{% set b_level = states('sensor.YOUR_BATTERY') | int %}
{{ ((-150 * b_level) + 7950)|round(-2)|int | timestamp_custom("%H:%M:00", false) }}
entity_id: timer.YOUR_TIMER
If you describe how the rest of the automation is supposed to work we can likely help you put all the pieces together.
now is like this
alias: pulse elite charging
description: ""
- platform: state
entity_id:
- binary_sensor.pulse_elite_charger
to: "on"
for:
hours: 0
minutes: 0
seconds: 0
- platform: numeric_state
entity_id:
- sensor.presa_termosifone_scrivania_switch_0_power
for:
hours: 1
minutes: 5
seconds: 0
above: 1
condition: []
- choose:
- conditions:
- condition: trigger
id:
- "on"
- condition: template
value_template: >-
{{ now() - state_attr('automation.avvio', 'last_triggered') >
timedelta(minutes=2) }}
- condition: numeric_state
entity_id: sensor.pulse_elite_battery_level_last
below: 27
- condition: state
entity_id: input_boolean.pulse_elite_charged
state: "off"
value_template: >-
{{ now() - states('sensor.z2m_last_updated') | as_datetime |
as_local > timedelta(minutes=2) }}
sequence:
- service: switch.turn_on
metadata: {}
data: {}
entity_id: switch.presa_termosifone_scrivania_switch_0
- conditions:
id:
- "off"
- condition: state
entity_id: binary_sensor.pulse_elite_charger
state: "on"
sequence:
metadata: {}
data: {}
- service: switch.turn_off
metadata: {}
data: {}
mode: single
but this way i have to modify the on time everytime the charge is below 27% (percentage before the last turn off) for the battery to arrive at 80%
but if i have to do it manually it’s not an automation anymore
You’ll need to create a timer helper and paste its entity ID in the 2 marked places.
description: ""
- id: "on"
platform: state
entity_id:
to: "on"
- id: "off"
platform: event
event_type: timer.finished
event_data:
entity_id: ## YOUR TIMER ##
condition: []
- choose:
- conditions:
value_template: >-
{{ now() - state_attr('automation.avvio', 'last_triggered') > timedelta(minutes=2) }}
below: 27
- condition: state
state: "off"
value_template: >-
sequence:
- service: timer.start
duration: |
{% set b_level = states('sensor.pulse_elite_battery_level_last') | int %}
- conditions:
- condition: state
state: "on"
sequence:
mode: single
like this?
the reset option has to be checked or unchecked?
coud you plese insert your modification here? i’m a little disoriented by yaml so i’m afraid i will make some mistake
description: ""
- platform: state
entity_id:
to: "on"
for:
hours: 0
minutes: 0
seconds: 0
entity_id:
for:
hours: 1
minutes: 5
seconds: 0
above: 1
- platform: state
entity_id:
- sensor.pulse_elite_battery_level
for:
hours: 0
minutes: 2
seconds: 0
- platform: state
entity_id:
id: "in use "
- platform: state
entity_id:
id: "non in use "
to: unavailable
- platform: state
entity_id:
- script.ps5_watch
- script.pc_watch
- script.switch_watch
id: ps link sync
condition: []
- choose:
- conditions:
id:
- "on"
value_template: >-
below: 27
- condition: state
state: "off"
value_template: >-
sequence:
metadata: {}
data: {}
- conditions:
id:
- "off"
- condition: state
state: "on"
sequence:
metadata: {}
data: {}
metadata: {}
data: {}
- conditions:
id:
- used
value_template: >-
value_template: >-
sequence:
- service: input_boolean.turn_off
metadata: {}
data: {}
- conditions:
id:
- "in use "
sequence:
metadata: {}
data: {}
entity_id: switch.ps_link
- conditions:
id:
- "non in use "
sequence:
metadata: {}
data: {}
- conditions:
id:
- ps link sync
- condition: not
conditions:
- condition: state
state: unavailable
sequence:
metadata: {}
data: {}
- delay:
hours: 0
minutes: 0
seconds: 2
milliseconds: 0
metadata: {}
data: {}
mode: single
before i cut the other condition to make the automation more readable
Checked
description: ""
- platform: state
entity_id:
to: "on"
- id: "off"
platform: event
event_data:
entity_id: timer.pulse_elite_charging_timer
- platform: state
entity_id:
for:
hours: 0
minutes: 2
seconds: 0
- platform: state
entity_id:
id: "in use "
- platform: state
entity_id:
id: "non in use "
to: unavailable
- platform: state
entity_id:
- script.ps5_watch
- script.pc_watch
id: ps link sync
condition: []
- choose:
- conditions:
id:
- "on"
value_template: >-
below: 27
- condition: state
state: "off"
value_template: >-
sequence:
metadata: {}
data: {}
duration: |
- conditions:
id:
- "off"
- condition: state
state: "on"
sequence:
metadata: {}
data: {}
metadata: {}
data: {}
- conditions:
id:
- used
value_template: >-
value_template: >-
sequence:
metadata: {}
data: {}
- conditions:
id:
- "in use "
sequence:
metadata: {}
data: {}
- conditions:
id:
- "non in use "
sequence:
metadata: {}
data: {}
- conditions:
id:
- ps link sync
- condition: not
conditions:
- condition: state
state: unavailable
sequence:
metadata: {}
data: {}
- delay:
hours: 0
minutes: 0
seconds: 2
milliseconds: 0
metadata: {}
data: {}
mode: single
thanks a lot
