Timerify: "run for 10 minutes" for any switch, without automations
Hi all,
I have a water boiler on a smart switch. For a long time it ran on a pile of helpers. A timer helper. An automation that turned the boiler on when the timer started and off when it ended. Another one that turned it off after two hours, in case I forgot. Two buttons, “Add 15 min” and “Reset”. Then I wanted to say “turn on the boiler for half an hour”, and that meant more automations and a few templates.
It worked. But every new device meant copying the whole set again. So I wrote Timerify.
You pick an entity you already have, and Timerify adds a timer to it, on the same device page. It is the same idea as Powercalc: it attaches to your device instead of making a new one.
What each timer gives you:
  • A “Run for” number. Set 10, and the device turns on and turns itself off after 10 minutes.
  • An “Ends at” sensor, so you can see when it will turn off.
  • Commands for later: turn on at 7:00, turn off in 20 minutes.
  • A weekly schedule, by weekday or by a Workday sensor.
  • A limit for when someone turns the device on by hand and forgets it. My boiler now turns off after two hours, like my old automation did.
  • A runtime sensor, if you want it: how many minutes the device was on.
  • Voice with the built-in Assist agent, in English and Russian: “turn on the boiler for 10 minutes”, “how long is left on the boiler”, “turn off the boiler at half past 7”. LLM agents get tools for the same things.
  • A dashboard card, as a pill or a round tile, with a ring that shows the time left.
It works with switches, lights, fans, input booleans and climate entities. Everything is set up in the UI, no YAML.
My old helpers and automations for the boiler are gone. It has one timer now.
Install
You install it with HACS (on Home Assistant 2026.11 and later, the Marketplace). It is not in the default list yet, so add it as a custom repository, or use this link:
Code and docs:
It needs Home Assistant 2026.10.4 or newer. If something does not work, or you miss something, open an issue on GitHub. I will try to read them all.
