FYI, the version I created triggered at noon today. I have reset it to trigger again tomorrow. I’m confident it will work again tomorrow for me and for you on October 11th.
Sounds good, for me i have a next pickup date in 5 days, will let know the result,
If all okay, i will mark it as the solution.
It works, i can the notification trought the telegram service,
Marked the post as the solution, .astimezone() did the trick,
many thanks.
I’m still to stupid.
In Nodered and Json, I succeeded already to concatenate some values from different “payload messages”
Like:
let num7 = msg.payload7;
Now I want to add the timestamp of the message in a readable format
I tried already several examples but I’ve always an error:
Like: let time = msg.payload7.timestamp;
Gves a “tim undefined” answer in debug screen
How can I extract thedate and the time from a message?
Timestamp of what? and what you need to do with it? What you tried? Give more info
For simple way you can use
var textdate=new Date(msg.payload).toISOString().replace(/\..+/,'');
or for custom display based on Date - JavaScript | MDN
Thank you.
I still have to learn a lot.
I have already the date & time in my string, concatenated with other values.
In my function object, I’m returning the string :
msg.payload = ans;
return msg;
And the string shows up correctly in the debug screen.
But how can I send this string in a notify object
My notify/email functions correctly, but when sending a text message.
Now I want to send the string I made in the function.
This does not work :
How can I send the output of my function?
In json type something as
"title":"Temp",
"data":{ "message": msg.payload}
If it’s not exact I can check later in nodered, I am not at computer currently.
Thanks for your answer
But it gives a syntax error
Replace msg.payload with “{{ payload}}”
“title”: “Temp”,
“data”: {“{{payload}}”}
→ Syntax checking gives Bad string
“title”: “Temp”,
“data”: {{payload}}
→ Gives also bad string
“title”: “Temp”,
“data”: “{{payload}}”
Is accepted but gives error on execution.
“title”: “Temp”,
“data”: “{{msg.payload}}”
Based on this
If this can help.
This syntax works and sends a notify/email with a snapshot image of a camera. (thanks to a forum member)
But how to send a string message coming from a preceeding function object?
“title”: “Beweging voordeur”,
“message”: “Beweging voordeur”,
“data”: {
“images”: [
“/config/tmp/snapshot_camera_voordeur.jpg”
I am still on mobile but as I said just replace msg.payload with {{payload}}
“title”:“Temp”,
“data”:{ “message”: msg.payload}
“title”:“Temp”,
“data”:{ “message”: {{payload}}}
