I’m using the Rova integration, this integration shown me when i have to take the trash out.
The integration gives me a timestamp for the next pickup, I now have a automation rule that send a telegram message when this date changes. (so i have to take the trash out next morning), this is working fine.
But i like to have this the evening before the date changes. So basicly the timestamp minus 12 hours.
How can a set the automation to do this?
I can’t figure out to take this timestamp -12 hour and trigger the telegram automation.
Yes exactly, When this date expires, a new one is give (for example 4 weeks lates)
This 12th october is the date that they do the pickup, (can be very early in the morning)
So you have to put it at the 11th at the end of the day, so 12th october minus a couple of our, then trigger to automation to send the message
That looks okay, just to know: why does the T disaplear?
Do i have to use this template as tigger now? or do have to create another template sensor in my configuration file? and use this new sensor as the trigger? or is there a better way?
Look at what you selected “Value of a date/time helper”. It only lists input_datetime entities.
Basically, you have discovered one of the Automation Editor’s several deficiencies, in this case it lacks the means of selecting a timestamp sensor even though that’s a valid choice for a Time Trigger. You have to switch to YAML mode and manually enter the sensor’s entity_id.
On a separate note, the Template Sensor configuration you posted is unformatted. Here’s the formatted version:
Please consider marking my post (above) with the Solution tag. It will automatically place a check-mark next to the topic’s title which signals to other users that this topic has been resolved. It will also place a link below your first post that leads to the solution post. All of this helps users find answers to similar questions. For more information, refer to guideline 21 in the FAQ.
There are no other triggers for this, and no conditions,
So why is this automation not triggering?
The automation should have triggered at 4th october mid day, (as this is shown by the “sensor.rova_residual_adjusted”
