Timestamp_Custom format
By piecing together the posts of a few others, I have successfully created a display to show me how long my home is unoccupied by using a combination of a counter and a timer that indexes the counter every minute. So, from that the counter value is the number of minutes my home is unoccupied. I can show that counter value and recognize that it’s minutes but I’ve tried to show it in hours and days for times when it is unoccupied and that’s where I’ve stumbled. I’m using the timestamp_custom format below but there are 2 issues:
  1. By default, it sees the counter value as seconds and not minutes. Even if I leave out the %S, it still sees it as seconds. I can have the timer index every second but that is not needed. Can I have timestamp_custom directly recognize that this value is in minutes without multiplying it or indexing the counter ever second?
  2. When I include %d, I immediately get 1 day showing even if the unoccupied time is only a few minutes. How can I roll the “Days” over only after I have truly crossed over 23:59 hours?
Below is what I’m currently using:
{{ states('counter.home_unoccupied') | int ) | timestamp_custom('%d:%H:%M:%S', true) }}
You really don’t need all that. HA has entities specific for this kind of thing. You can create a last occupied sensor, and then a duration sensor. The rest will be handled by HA. No counters, no automations, just template sensors.
template:
- trigger:
  - id: left
    platform: state
    entity_id: zone.home
    to: "0"
  - id: arrived
    platform: state
    not_to: "0"
  - name: Last Occupied
    unique_id: last_occupied
    device_class: timestamp
    state: >
      {{ now() }}
    availability: >
      {{ trigger.id == 'left' }}
- sensor:
  - name: Unoccupied Time
    unique_id: unoccupied_time
    device_class: duration
    unit_of_measurement: s
    state: >
      {{ (now() - states('sensor.last_occupied') | as_datetime).total_seconds() | int }}
    availability: >
      {{ 'sensor.last_occupied' | has_value }}
In the UI the last_occupied will be a relative time, e.g. 15 Minutes Ago
In the UI the Unoccupied time will be d HH:MM:SS, e.g. 00:15:00 for 15 minutes. or 1 day, 00:15:00 for 1 day and 15 minutes.
Wow!. I learn new features every day. Thanks for that information. That will be very helpful.
I copied and pasted exactly and placed in my configuration.yaml file. It shows no errors but the sensor shows unavailable, even after a reboot.
Did someone come or go? Trigger-based template sensors will be unknown when created until the first time it was triggered. After that, it will always have the last state, even after a restart.
I did have an unoccupied state happen and still got that. I have not been using a templates.yaml file and tried this code within the configuration.yaml file and also added a templates.yaml file and referenced it in the configuration.yaml file and get the same either way.
I see this in the logs:
Logger: homeassistant.config
Source: config.py:978
First occurred: 11:23:21 AM (1 occurrences)
Last logged: 11:23:21 AM
Invalid config for [template]: [template] is an invalid option for [template]. Check: template->template. (See /config/templates.yaml, line 1).
You put template inside template, can you post your configuration.yaml and any other files you included with template?
The code above is all that is in my templates.yaml file copied and pasted.
Config file is:
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
# Text to speech
tts:
  - platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
sensor: !include sensors.yaml
template: !include templates.yaml
proximity:
  home:
    devices:
      - person.dad
      - person.mom
      - person.Dave
    tolerance: 50
    unit_of_measurement: mi
# Example configuration.yaml entry previous platform: trend
binary_sensor:
    sensors:
      hvac_fan_on:
        friendly_name: "HVAC Fan On"
        entity_id: climate.my_home_2
        value_template: "{{ is_state_attr('climate.my_home_2','fan', 'on') }}"
I removed template: from the top of the file and the log error went away. I’ll try an occupancy cycle and see if it works otherwise.
Yes, if you’re including the file, you omit the integration knew in the file because it’s provided by the include
When I uncomment templates, I don’t get errors but other sensors quit working.
A full reboot of the server brought everything back up. Looks like the template is working now. Thank you all!
I tried several home/away cycles today but this is not triggering for some reason. My other away/home automatons are working and the attached trend shows I’m getting transitions to: 0 and not_to 0. Any reason why this template would not trigger and show the time away?
