I’m working on some calculations with the Xfinity usage add-on and having trouble with the timestamp_custom portion of date formatting. I’ve got the following code in as a sensor:
xfinity_bill_end_date:
value_template: '{{ as_timestamp(strptime(states.sensor.xfinity_usage.attributes.end_date, "%m/%d/%Y")) | timestamp_custom('%A, %B %d') }}'
friendly_name: 'Xfinity Billing Period Start'
and am getting an error during configuration check:
while scanning for the next token found character '%' that cannot start any token in "/config/sensors.yaml"
Fairly certain I am using the timestamp_custom integration correctly, and have had success with the same code with the template developer tool.
