Timestamp sensor for Wake-up light alarm with sunrise effect blueprint
I have spend hours on trying to understand how to setup the timestamp sensor for the Wake-up light alarm with sunrise effect. The blueprint is working when setting the timer manually. I would like to use shortcuts app on my iPhone to set the alarm automatically via the calendar. I have enabled the ‘date_time_iso’ and ‘date’ sensors.
I have searched the forum and tried creating different sensors like Using an input helper to update a timestamp sensor and setting the timer from a helper with date and time.
But nothing works… I am not able to get it to work.
Thank you for your help.
Same problem…
I found a working solution here Wake-up light alarm with sunrise effect - #295 by khr
Great thanks =) I’m gonna try it out soon =)
