Timestamp template not working as sensor, but works in template editor
I do try to create a timestamp template sensor.
This is working in the template editor, but not as sensor.
What am I doing wrong?
the sensor:
as sensor in sensor.yaml:
    status:
      value_template: '{{ state_attr("vacuum.xiaomi_vacuum_cleaner", "status") }}'
      icon_template: mdi:list-status
      unit_of_measurement: ""
      friendly_name: "Status"
    clean_start:
      value_template: '{{ as_timestamp(states("sensor.xiaomi_vacuum_cleaner_last_clean_start")) | timestamp_custom("%d-%m-%Y %H:%M") }}'
      icon_template: mdi:clock-start
      friendly_name: "Starttijd"
    clean_stop:
      value_template: '{{ as_timestamp(states("sensor.xiaomi_vacuum_cleaner_last_clean_end")) | timestamp_custom("%d-%m-%Y %H:%M") }}'
      icon_template: mdi:timer-off-outline
      friendly_name: "Stoptijd"
the result:
Good it be that creating : sensor.xiaomi_vacuum_cleaner_last_clean_start is delayed after startup and not existing trying to make a template?
Please post your templates using the community standards. It allows folks to test your code without rewriting from a pic.
Please don’t post code as an image. People trying to help have to type it over.
Thanks. I will change the question
Test
{{ as_timestamp(states('sensor.xiaomi_vacuum_cleaner_last_clean_start'), 0) | timestamp_custom('%d-%m-%Y %H:%M') }}
Requirement for timestamp device class is:
  • timestamp: Datetime object or timestamp string (ISO 8601)
Yours is neither of those. Use the isoformat() filter to get an ISO8601 string that can be classified as device_class: timestamp.
Also, you are creating legacy-config template sensors (under sensor: domain heading). You should consider rewriting in modern configuration (under template:) — or create them via the UI under Helpers and not have to worry about YAML:
Thanks for the answer
