Hi there,
I dont even know under what category I should put this, but anyway
I was tired of the useless Home Assistant Cloud button always appearing on my Settings page and unable to remove it (from what I read around here) so I created a little Tampermonkey / Greasemonkey script to get rid of it:
Feel free to download it, update it, change it to your needs…
It’s not ideal since it is client side, but at least it’s a workaround.
thanks for the tip, but I’m afraid that path was quite more difficult than developing this for me.
“don’t use default_config” was what I found initially to solve this, but that only meant removing the default_config: on configuration.yaml, which led me to not know how to proceed to manage content myself properly, as that is never explained where and how to do
also, right before the default_config line, it says
# Loads default set of integrations. Do not remove.
which is a bit scary for a newbie to touch when it explicitly says do not remove !
