TKB TZ56D: recognized as TZ56S (= only one button is working
Has someone some experience with Paddle Wall Double Switch TKB TZ56D?
My Switch is recognized but the second button is not working.
First I checked the OZW log and found some lines about first working button:
2019-01-14 22:18:39.801 Detail, Node005, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x05, 0x03, 0x25, 0x03, 0xff, 0x2d
2019-01-14 22:18:39.801 Info, Node005, Received SwitchBinary report from node 5: level=On
2019-01-14 22:18:39.802 Detail, Node005, Refreshed Value: old value=false, new value=true, type=bool
2019-01-14 22:18:39.802 Detail, Node005, Changes to this value are not verified
2019-01-14 22:18:39.802 Detail, Node005, Notification: ValueChanged
But there are no lines after clicking second button!
The I saw that the device is named as “Wenzhou TKB Control System TZ56S On/Off wall switch”. This is wrong TZ56S is a single button switch, I have TZ56D with two buttons. Could this be the problem? How can I force the switch to be TZ56D?
here the inforamtion about the recognized switch:
node id: 5
node name: Wenzhou TKB Control System TZ56S On/Off wall switch
manufacturer name: Wenzhou TKB Control System
product name: TZ56S On/Off wall switch
query stage: Complete
is awake: true
is ready: true
is failed: false
is info received: true
max baud rate: 40000
is zwave plus: true
capabilities: listening, routing, zwave_plus, beaming
neighbors: 1, 2, 3
sentCnt: 18
sentFailed: 0
retries: 0
receivedCnt: 20
receivedDups: 1
receivedUnsolicited: 8
sentTS: 2019-01-14 23:02:23:974
receivedTS: 2019-01-14 23:02:02:342
lastRequestRTT: 23
averageRequestRTT: 27
lastResponseRTT: 36
averageResponseRTT: 44
by the way: when I retrieve information by “print node” in the zwave network management tab of hassio I get this in ozw log:
20> 19-01-14 23:08:49.845 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-01-14 23:08:49.845 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-01-14 23:08:49.846 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-01-14 23:08:49.848 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-01-14 23:08:49.851 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-01-14 23:08:49.853 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-01-14 23:08:49.854 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-01-14 23:08:49.866 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-01-14 23:08:49.868 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-01-14 23:08:49.869 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-01-14 23:08:49.871 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-01-14 23:08:49.872 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-01-14 23:08:49.874 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-01-14 23:08:49.875 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-01-14 23:08:49.877 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-01-14 23:08:49.878 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-01-14 23:08:49.880 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-01-14 23:08:49.882 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-01-14 23:08:49.883 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-01-14 23:08:49.885 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-01-14 23:08:49.886 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-01-14 23:08:49.888 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-01-14 23:08:49.889 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-01-14 23:08:49.890 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-01-14 23:08:49.892 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-01-14 23:08:49.893 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
Any hints would be great! Thanks
