TKB TZ65d - multi level switch wrongly reported in home assistant interface
I have a TKB TZ65D, it is integrated in home assistant, but when I switch on the light from the switch, it reports brightness=8 (in HA), when I switch off from the switch it report brightness=242 (in HA).
if I only control from the interface of home assistant, no issues, only when I use both the physical switch and interface it gets all mixed up.
I can’t figure out what can be done at config level.
log when I switch on:
2020-04-03 15:09:27.917 Info, Node023, UPDATE_STATE_NODE_INFO_RECEIVED from node 23
2020-04-03 15:09:27.917 Detail, Node023, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Dynamic live=1
2020-04-03 15:09:27.917 Detail, Node023, QueryStage_Dynamic
2020-04-03 15:09:27.917 Detail, Node023, Queuing (Send) SwitchMultilevelCmd_Get (Node=23): 0x01, 0x09, 0x00, 0x13, 0x17, 0x02, 0x26, 0x02, 0x25, 0x6b, 0x9a
2020-04-03 15:09:27.917 Detail, Node023, Queuing (Query) Query Stage Complete (Dynamic)
2020-04-03 15:09:27.917 Info, Node023, Sending (Send) message (Callback ID=0x6b, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=23): 0x01, 0x09, 0x00, 0x13, 0x17, 0x02, 0x26, 0x02, 0x25, 0x6b, 0x9a
2020-04-03 15:09:27.925 Detail, Node023,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-04-03 15:09:27.925 Detail, Node023,   ZW_SEND_DATA delivered to Z-Wave stack
2020-04-03 15:09:27.942 Detail, Node023,   Received: 0x01, 0x07, 0x00, 0x13, 0x6b, 0x00, 0x00, 0x02, 0x82
2020-04-03 15:09:27.942 Detail, Node023,   ZW_SEND_DATA Request with callback ID 0x6b received (expected 0x6b)
2020-04-03 15:09:27.942 Info, Node023, Request RTT 24 Average Request RTT 24
2020-04-03 15:09:27.942 Detail,   Expected callbackId was received
2020-04-03 15:09:27.953 Detail, Node023,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x17, 0x03, 0x26, 0x03, 0x03, 0xc0
2020-04-03 15:09:27.953 Info, Node023, Response RTT 35 Average Response RTT 34
2020-04-03 15:09:27.953 Info, Node023, Received SwitchMultiLevel report: level=3
2020-04-03 15:09:27.953 Detail, Node023, Refreshed Value: old value=94, new value=3, type=byte
2020-04-03 15:09:27.953 Detail, Node023, Changes to this value are not verified
2020-04-03 15:09:27.953 Detail, Node023,   Expected reply and command class was received
2020-04-03 15:09:27.953 Detail, Node023,   Message transaction complete
2020-04-03 15:09:27.953 Detail, Node023, Removing current message
2020-04-03 15:09:27.953 Detail, Node023, Notification: ValueChanged
2020-04-03 15:09:27.955 Detail, Node023, Query Stage Complete (Dynamic)
2020-04-03 15:09:27.955 Detail, Node023, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
2020-04-03 15:09:27.955 Detail, Node023, QueryStage_Configuration
2020-04-03 15:09:27.955 Detail, Node023, QueryStage_Complete
2020-04-03 15:09:27.955 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=1
2020-04-03 15:09:27.955 Warning, CheckCompletedNodeQueries all=0, deadFound=0 sleepingOnly=1
2020-04-03 15:09:27.955 Detail, Node023, Notification: NodeQueriesComplete
log when I switch off:
2020-04-03 15:10:47.562 Info, Node023, UPDATE_STATE_NODE_INFO_RECEIVED from node 23
2020-04-03 15:10:47.562 Detail, Node023, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Dynamic live=1
2020-04-03 15:10:47.562 Detail, Node023, QueryStage_Dynamic
2020-04-03 15:10:47.562 Detail, Node023, Queuing (Send) SwitchMultilevelCmd_Get (Node=23): 0x01, 0x09, 0x00, 0x13, 0x17, 0x02, 0x26, 0x02, 0x25, 0x6c, 0x9d
2020-04-03 15:10:47.562 Detail, Node023, Queuing (Query) Query Stage Complete (Dynamic)
2020-04-03 15:10:47.562 Info, Node023, Sending (Send) message (Callback ID=0x6c, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=23): 0x01, 0x09, 0x00, 0x13, 0x17, 0x02, 0x26, 0x02, 0x25, 0x6c, 0x9d
2020-04-03 15:10:47.570 Detail, Node023,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-04-03 15:10:47.570 Detail, Node023,   ZW_SEND_DATA delivered to Z-Wave stack
2020-04-03 15:10:47.587 Detail, Node023,   Received: 0x01, 0x07, 0x00, 0x13, 0x6c, 0x00, 0x00, 0x03, 0x84
2020-04-03 15:10:47.587 Detail, Node023,   ZW_SEND_DATA Request with callback ID 0x6c received (expected 0x6c)
2020-04-03 15:10:47.587 Info, Node023, Request RTT 24 Average Request RTT 24
2020-04-03 15:10:47.587 Detail,   Expected callbackId was received
2020-04-03 15:10:47.597 Detail, Node023,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x17, 0x03, 0x26, 0x03, 0x5e, 0x9d
2020-04-03 15:10:47.597 Info, Node023, Response RTT 34 Average Response RTT 34
2020-04-03 15:10:47.597 Info, Node023, Received SwitchMultiLevel report: level=94
2020-04-03 15:10:47.597 Detail, Node023, Refreshed Value: old value=3, new value=94, type=byte
2020-04-03 15:10:47.597 Detail, Node023, Changes to this value are not verified
2020-04-03 15:10:47.597 Detail, Node023,   Expected reply and command class was received
2020-04-03 15:10:47.597 Detail, Node023,   Message transaction complete
2020-04-03 15:10:47.597 Detail, Node023, Removing current message
2020-04-03 15:10:47.597 Detail, Node023, Notification: ValueChanged
2020-04-03 15:10:47.601 Detail, Node023, Query Stage Complete (Dynamic)
2020-04-03 15:10:47.601 Detail, Node023, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
2020-04-03 15:10:47.601 Detail, Node023, QueryStage_Configuration
2020-04-03 15:10:47.601 Detail, Node023, QueryStage_Complete
2020-04-03 15:10:47.601 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=1
2020-04-03 15:10:47.601 Warning, CheckCompletedNodeQueries all=0, deadFound=0 sleepingOnly=1
2020-04-03 15:10:47.601 Detail, Node023, Notification: NodeQueriesComplete
Thanks for your help!
Michel
@michmtt Did you find the solution?
I have also issue with this swiych as with the automatic discovy it is discovered as TZ55S. Tried to rediscover and no luck.
