rt1970
(Rene T.)
1
Hi!
How can i dim TM1637 from time to time (night)?
Or from sun entity?
time:
- platform: homeassistant
display:
platform: tm1637
clk_pin: D6
dio_pin: D5
update_interval: 500ms
lambda: |-
static int i = 0;
i++;
if ((i % 2) == 0)
it.strftime("%H.%M", id(homeassistant_time).now());
else
it.strftime("%H%M", id(homeassistant_time).now());
zoogara
(Daryl)
2
I assume the code you have already displays the time?
If so, this may work. The set_intensity
function exists in the API, the code compiles, but It don’t have a display to test:
lambda: |-
static int i = 0;
i++;
if ((i % 2) == 0)
else
if (id(homeassitant_time).now().hour < 7) {
it.set_intensity(2);
} else if ((id(homeassitant_time).now().hour >= 7) && (id(homeassitant_time).now().hour < 20)) {
it.set_intensity(7);
} else {
