To keep record with updates
Hi! I am new in this forum and first I want to greet you all.
Every time I update the Home Assistant, the sensor data record is deleted and stored again from the time the update is made. Is there a way to keep that record with updates?
I keep the data in MariaDB now, and I thought it kept them that way, but it stays the same.
That should definitely not happen.
What type of installation are you running and how are you updating?
I use Docker and RPi4 (with raspberry os).
For example, in this image is seen how in october 25th I updated HA, because it keeps the data from then on, but the data is not kept until then.
Hi, are you sure it is related to upgrading?
Or can it perhaps be the 10 day default period that the recorder keeps data?
I was sure that the problem was the update, but I am not sure not. I will try with the next update.
Thanks!
