Hey everyone. I’m a newbie to Home Assistant. Thanks to some forums (including this site), youtube tutorials and chatGPT, I managed to setup something functionnal and pretty. I still implement new automations, but i finished the light automation.
I would like to know, have i gone too far already ? Are my automations too complex ?
The whole setup is very human friendly and i don’t think i could achieve this in a much simpler way. However, i wonder if this is too much. Sometimes, some automations / scenes take time to take effect. I also have some errors in the Home assistant log.
Below, you will find an example of my light automation setup.
Here is an example of the light automations in “Salon” (lets call it Room1) which has 2 light bulbs and 1 motion sensor :
I first created 4 scenes : “Room1 Off”, “Room1 Day”, “Room1 Evening”, “Room1 Night”. For each scene i have 2 light bulbs connected via Zigbee and different light settings.
I then have 4 automations, 1 input select and 2 virtual switches :
automation 1 to “debug” all the lights when changing light mode (the problem was : Playing → “Room1 Day” → “Room1 Off” → “Room1 Night” resulted in a short (and way to bright) trigger of the “Room1 Day” scene before effectively triggering “Room1 Night”.)
automation 2 to toggle virtual switch 1 depending on the inputs from the motion / lux sensor.
automation 3 to play “Room1 Day”, “Room1 Evening”, “Room1 Night” scene based on the input select state (Day, Evening, Night) triggered by the virtual switch going from off to on.
automation 4 to play “Room 1 Off” scene triggered by the virtual switch going from on to off.
input select to choose between the different light modes for the whole house
virtual switch 1 to pilot lights and link automations
virtual switch 2 that controls the first virtual switch. It overrides (used as a condition) the automation 2 and is used to trigger manually automation 3 and automation 4. I wanted this so the manual switch is not shown as “on” if the light is only triggered by the automation 2.
Another switch enables / disables the automation 2.
You can duplicate everything above 2 times since i have 3 rooms controlled the same way.
I hope you can understand me, if you don’t feel free to ask questions.
Home assistant is running on a VM on Windows. It has an intel celeron N3350 and 2gb of RAM allowed. Installed on an SSD.
I think there might be an undefined entity in the blueprint I used to create 2 automations “Mouvement Salon” and “Mouvement Couloir”. I’m not sure how to read the logs and identify the problem though.
# Home Assistant Core
2023-03-28 09:27:37.945 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration virtual which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-28 09:27:37.952 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration tapo_control which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-28 09:27:37.955 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-28 09:28:41.719 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.iloratapo_privacy is taking over 10 seconds
2023-03-28 10:16:44.455 ERROR (MainThread) [frontend.js.latest.202303091] http://100.91.18.22:8123/lovelace/lumieres:0:0 Uncaught
2023-03-28 10:39:52.102 ERROR (MainThread) [frontend.js.latest.202303091] http://100.91.18.22:8123/lovelace/lumieres:0:0 Uncaught
2023-03-28 11:03:29.715 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
In 'condition' (item 4 of 6):
In 'or' (item 5 of 5):
In 'template' condition: UndefinedError: 'dict object' has no attribute 'entity_id'
2023-03-28 11:03:59.050 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 11:04:02.915 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Couloir':
2023-03-28 11:12:14.554 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 11:16:19.394 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Couloir':
2023-03-28 11:17:10.782 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Couloir':
2023-03-28 11:17:16.933 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 11:27:19.185 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 11:27:50.040 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 11:28:09.230 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 11:28:17.249 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Couloir':
2023-03-28 11:28:59.422 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Couloir':
2023-03-28 11:29:02.621 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 11:32:20.361 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 11:32:28.691 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Couloir':
2023-03-28 11:32:53.962 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Couloir':
2023-03-28 11:33:00.455 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 11:33:24.169 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 11:34:10.069 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 11:35:28.219 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 11:36:00.453 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 11:36:27.381 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 11:36:46.216 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 11:37:48.346 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Couloir':
2023-03-28 11:38:03.646 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 11:38:17.544 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Couloir':
2023-03-28 11:38:32.808 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 11:38:51.013 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Couloir':
2023-03-28 11:39:14.713 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Couloir':
2023-03-28 11:41:47.931 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Couloir':
2023-03-28 11:41:53.718 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 11:42:08.300 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 11:42:25.608 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Couloir':
2023-03-28 11:43:05.870 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Couloir':
2023-03-28 11:43:31.108 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Couloir':
2023-03-28 11:43:34.309 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 11:44:33.554 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 11:44:59.667 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 11:46:09.492 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 11:55:11.173 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:00:15.143 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:01:24.862 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:03:36.912 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:09:33.423 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:09:59.999 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:11:27.208 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:14:05.126 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:15:37.436 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:16:18.747 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:16:40.444 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:18:20.851 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:23:45.271 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:24:14.669 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:24:54.721 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:33:07.362 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:34:28.547 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:35:09.451 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:35:39.160 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:36:38.413 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:49:41.848 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:53:42.954 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:54:42.081 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:55:11.465 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:55:31.861 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:55:58.887 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:57:03.070 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:57:47.665 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:58:45.564 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 12:59:25.076 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 13:00:03.737 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 13:00:30.292 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 13:01:07.174 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 13:01:51.289 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 13:02:48.650 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 13:03:42.358 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 13:04:40.764 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 13:04:58.038 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 13:05:16.583 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 13:05:52.149 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 13:06:37.776 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 13:07:34.380 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 13:33:55.472 ERROR (MainThread) [frontend.js.latest.202303091] http://192.168.31.8:8123/lovelace/lumieres?external_auth=1:0:0 Uncaught
2023-03-28 13:34:24.766 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 13:35:57.439 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 13:37:52.249 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
2023-03-28 13:39:29.890 WARNING (MainThread) [homeassistant.components.automation] Error evaluating condition in 'Mouvement Salon':
Ok thanks. I felt it was something pretty okay for a computer to handle
I was just worried about the errors in the log. I will take a look at this.
There is still some errors i don’t understand in the log. Should i take care of it ? They don’t occure a lot (Extract from log):
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/connection.py:162
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 14:03:24 (1 occurrences)
Last logged: 14:03:24
[139917221573392] Error handling message: Integration '' not found (unknown_error) AdrienSarah from 127.0.X.X (Mozilla/5.0 (X11; CrOS x86_64 14541.0.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/111.0.0.0 Safari/537.36)
Logger: frontend.js.latest.202303091
Source: components/system_log/__init__.py:254
First occurred: 10:16:44 (4 occurrences)
Last logged: 13:57:35
http://100.91.XX.XX:8123/lovelace/lumieres:0:0 Uncaught
http://192.168.XX.X:8123/lovelace/lumieres?external_auth=1:0:0 Uncaught
Logger: homeassistant.helpers.entity
Source: helpers/entity.py:541
First occurred: 09:28:41 (1 occurrences)
Last logged: 09:28:41
Update of switch.tapoC210_privacy is taking over 10 seconds
