HI All,
When pressing the “OPEN WEB UI” from a (any) addons info page, how do I open the web ui using the IP of home-assisant rather than the domain name I use to access HA normally?
My HA is installed on a Intel NUC, I have domain set through cloudflare and SSL via Traefik/lets encrypt and I normally access HA via my domain name (externally and internally), I can access from the IP address and addon web UIs work if I manually type in the IP and port detail - however when I try the button it defaults to the domain name:port.
It used to work - not sure when it stopped to be honest, I did move to proxmox VM at one point and that is when I noticed it not working, but I have moved back to BM and its still the same - not sure if I have changed anything to cause this, but if there is an obvious setting somewhere please let me know?
my config.yml http section looks like this:
http:
base_url: http://homeassistant.mydomain.com
ip_ban_enabled: true
login_attempts_threshold: 5
use_x_forwarded_for: true
trusted_proxies:
- 192.168.1.0/24
- 172.18.0.0/24
- 127.0.0.1
- ::1
- fe80::/64
- fe00::/64
- fd00::/64
thanks
Home Assistant 2023.3.5 Supervisor 2023.03.1 Operating System 9.5 Frontend 20230309.0 - latest
