To Proxmox or not to Proxmox
broker i have not checked with explorer since i don’t know how to do but it’s working since i put my shelly on it’s and all is working regulary. now i have finished with nodered, and mariadb too and all seems ok, only zigbee is giving me problem
Also, if you type cd /opt/zigbee2mqtt/data/log in the Zigbee2MQTT LXC console (hit enter) and then type ls (hit enter) is there anything showing?
What type of zigbee stick do you have? Do you know if it came pre-flashed?
CC2538 with onboard CC2592 amplifier yes it’s preflashed with the add on it was working fine
well, I see no reason why it wouldn’t start. If you installed it correctly.
Have you restarted the LXC?
really don’t understand i have done all again and same problem, is possible the path to the key is not correct?
your ls -l /dev/serial/by-id matched your port: in the config :man_shrugging:
the only thing that I see different in your configuration.yaml than the example is you left out version: 4 under mqtt:
I think it’s Optional
in new installation i have copyed exactly your configuration, just changed port, mqtt adress, user and pass
you now have pan_id and network_key so it started?
do again
ok why using ipadress:port i don’t see anythig? how i pair devices?
do a cat /opt/zigbee2mqtt/data/log/2022-01-24.16-28-28/log.txt
got this
now try your-lxc-ip:8099
The log shows that it is up and running
as soon as back home i try and let you know, i’m in office now i have the port forwarding setted but it’s not working from here
So, we can say that it is best to copy & paste the example configuration.yaml to get things going.
ahahah hope so
