Iβve done it stopped and running. But, I think stopped would be best. ( need to make script stop destination LXC)
It will now shutdown destination LXC before data transfer
missing the last 4 digits after the Configuration
Mine is: alexdelprete#5566
I tried running the copy script, from within the source plex container:
UPDATE: ran from proxmox nowβ¦but another error:
[INFO] Plex Media Server Data from '100' to '109'
Stopping '109'...
Mounting Container Disks...
bash: line 88: Support/Plex: No such file or directory
[ERROR] 127@88 Unknown failure occured.
run from Proxmox Shell
Stopping '109'...
probably the folders are created after you configure Plex the first timeβ¦
yep should I create them?
Yes but make sure Plex is stoppedβ¦
It stopped 109
ok try again
EDIT: The script was successfully created and available in the repo
Hu @tteck ,
Thanks for your work.
The add-on Portainer has been depreciated recently in HA a solution is to install it as a LXC.
Is it something you are planning to add ?
Thank you
The Home Assistant Container LXC script installs Portainer with HA, use that script, then just remove HA
how can i access from windows to lxc folders?
within the same network? If so, install Webmin on the LXC and use your browser to navigate to https://your-lxc-ip:10000
nice thanks
where is nodered lcx?
Node-Red LXC
all installed thanks to your guide.
i have this problems:
nodered 1(1 palette i used before to show cameras on homekit doesnβt esist anymore, for this reason i would copy the palette folder from old node red to the new one)
nodered 2 (always in node red i want save some video files temporaly in a folder so i want see node red folder structure to know where to save it)
mariadb (if i restart the minipc hassio start before than mariadb and this give problem to see the recorder, than i need to restart hassio after mariadb has started)
in mine i donβt see .nodered
for startup problem now i put 1 to mariadb and 6 to hassio since now this is my container
situation
Then you didnβt install Webmin on your Node-Red LXC
any script for homebridge?
