To Proxmox or not to Proxmox
@tteck fixed it - I had to add the ‘listener’ line to mosquitto.conf otherwise mqtt wont be allowed to listen for anything other than localhost (as per log file entry in post above):
# Place your local configuration in /etc/mosquitto/conf.d/
# A full description of the configuration file is at
# /usr/share/doc/mosquitto/examples/mosquitto.conf.example
pid_file /run/mosquitto/mosquitto.pid
persistence true
persistence_location /var/lib/mosquitto/
log_dest file /var/log/mosquitto/mosquitto.log
include_dir /etc/mosquitto/conf.d
listener 1883 0.0.0.0
Not sure if you can build that into the install script? Alternatively, I guess it can be added as a config line item on /etc/mosquitto/conf.d/default.conf?
UPDATE:
Just tested that out and it works fine if you edit /etc/mosquitto/conf.d/default.conf with the following:
allow_anonymous false
password_file /etc/mosquitto/passwd
Looks like Debian 11 has brought new versions of MQTT. port 1883 is deprecated and now requires listener 1883 I’m thankful that @Townsmcp has a good troubleshooting skill.
Can you change your default.conf to the following, and confirm it’s working
persistence true
listener 1883
EDIT: I can confirm everything is working as it should with the above config
Wondering this setup will give more advantage since I need to install each app manually on LXC rather than running on Docker?
Still debating whether I need to switch or remain running VM. Supervised so far is very nice and its auto-backup addon is the best.
Everyone has their preferred method to run Home Assistant. No right/wrong way as long as it’s a supported installation method.
I prefer this method because:
  1. total control (no supervisor)
  2. ease of troubleshooting
  3. individual lxc auto backups to a USB SSD drive with auto prune
  4. fast restores
  5. my key automation’s continue to function without Home Assistant
And most importantly, I’m comfortable with this method.
yeah… I should agree on the information, however most of my apps is running on Docker and I will have a headache to install it manually. For example install influxDB - Grafana
The Home Assistant Container LXC uses Portainer and Docker, so you can add docker containers.
Like I said, It’s what you’re comfortable with. Such a fun hobby!
so for HA container LXC is running on docker inside LXC nesting?
Yes. The good thing about Proxmox is you can create a VM or LXC and play around to see if things work for you without messing with your current, working setup.
Personally, I prefer to use Whiskerz script (found here GitHub - whiskerz007/proxmox_hassio_lxc) so that I can run HA as close to bare metal as possible rather than in a docker container. By using this method I still have access to Supervisor and add-on store (kind of the best of both worlds). But I am going through breaking down important integrations out to their own LXC’s - this is thanks to @tteck for individual LXCs. That way, as Tteck has said, you can keep plaing around without screwing everything up in a big way.
Just as a side note though, Whiskerz script is not Proxmox 7 compatible. However there is a Proxmox 7 pullrequest that justme88 corrected the PVE 7 issues. At least, it corrected it until apt-get update failed to work! I fed back the changes required to the pullrequest in the thread and it works pefectly now. It can be found at Update create_container.sh by justme88 · Pull Request #42 · whiskerz007/proxmox_hassio_lxc · GitHub. I havent Actpohomoc pullrequest yet though so cant vouch for that. But to get it working with the pullrequest, I just copy/pasted the code into a new local .sh file, modified the line and ran the script locally to get the new container running
Doesn’t that install method show “Unsupported” ?
It does unfortunately. However, since being on PVE 7 (and even on PVE 6) I havent had any problems from the install and everything is working much much better than was HA was on a PI4 with external SSD.
Im actually just doing the MariaDB script and so far can see a couple of differences to your documented changes to what is in the 50-server.cnf for Debian 11 container:
  1. ‘port’ and ‘socket’ lines are missing on default install.
  2. ‘skip-external-locking’ is uncommented
Not sure if I should change to your settings? Or go with the defaults and add ‘port’ line/comment out ‘skip-external-locking’?
Does it show " Unhealthy" ?
Not that I can see:
…unless Im looking in the wrong place?
run script again if you didn’t get it working
Debian 11 brought more changes than expected.
I’m working on new docs
As far as I understand this is just Home Assistant Supervised running in an LXC container instead of a VM. So Home Assistant, Supervisor and all add-ons still run in docker containers.
It’s not integrations that you are breaking up into LXCs, it’s add-ons/additional software like the mqtt broker that you break up into separate LXC containers.
Thanks. Think I will wait for the updated info - just built a new LXC, followed the install steps, but when it comes to adding the new admin account and accessing it I get the following:
root@mariadb:~# sudo mysql
Welcome to the MariaDB monitor.  Commands end with ; or \g.
Your MariaDB connection id is 55
Server version: 10.3.29-MariaDB-0+deb10u1 Debian 10
Copyright (c) 2000, 2018, Oracle, MariaDB Corporation Ab and others.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
MariaDB [(none)]> GRANT ALL ON *.* TO 'admin'@'192.168.1.%' IDENTIFIED BY 'myPassword' WITH GRANT OPTION;
Query OK, 0 rows affected (0.000 sec)
MariaDB [(none)]> FLUSH PRIVILEGES;
MariaDB [(none)]> exit
Bye
root@mariadb:~# mysql -u admin -p
Enter password:
ERROR 1045 (28000): Access denied for user 'admin'@'localhost' (using password: YES)
root@mariadb:~#
hehe couldnt think of the name (add-ons) so just went with integrations :slight_smile:
So, does that mean that Tteck’s script puts HA inside a docker inside a docker inside an LXC but Whiskaz is in an docker inside an LXC?
That’s a small but rather important difference :slight_smile:
No, whiskaz script installs Home Assistamt Supervised (with supervisor and add-ons, all running in docker containers) inside an LXC. Tteck script installs Home Assistant Container (no supervisor, no-addons, just Home Assistant in a docker container) inside an LXC.
As bare metal as possible would be running Home Assistant Core (Home Assistant in a virtual environment) in an LXC container.
Ah ok cool. Will give that a go as part of the new build. My only concerns are having the same functionality from various addons that I have installed (although a leaner HA will be nice - my current setup is using up 100gb storage):
Out of that lot, the main ones I would really want are log viewer, file editor, Google Drive backup, Grafana/Influx and some sort of terminal (which I guess I can replace functionality in Guacamole to ssh in from anywhere
Thank you for this detailed descriptions. It is really helpful.
