I finally found out what the problem was with my TOD helpers (I think…!
I want the outddor light to turn on 17 minutes before sunset, and turn off 17 minutes after sunrice.
I started with:
- platform: tod
after: sunset
after_offset: “-00:17”
before: sunrise
before_offset: “00:17”
In sometimes rather odd behaviour.
So I finally came to the conclusion do do the oposite go for when light should be turned off!
- platform: tod
after: sunrise
after_offset: “00:17”
before: sunset
before_offset: “-00:17”
and then used:
sensors:
outdoorlight:
friendly_name: “outdoorlight”
value_template: >-
{% set tmpvaluel = is_state(‘binary_sensor.outdoorlightinverse’,‘off’) %}
{{ tmpvaluel }}
This solutiion is steady as a rock, but confusing, is there a simpler solution, or possible to get an inverse parameter which defaults to ‘no’?
Like:
- platform: tod
inverse: yes
after: sunset
before: sunrise
And then swaps parameters and returns the inverse?
Through the year sunrise varies a bit… from about 2.00 am in summer to 10.00 am in winter.
Sorry about the indentaitions…
