I have cretaed an action fot the today widget on in Companion 2.0.0 (40) but how can I use this in automations in HA?
No one has any experience how to use the action part for automations in the companion app (44)?
very nice and works perfectly
Good afternoon, is the applewatch app working? The event is working, but by pressing the clock button nothing happens
Yep, plenty of people are reporting that the Apple Watch app and complications are working. Sometimes a little slow to update, but they work.
Ok, it worked perfectly.
Having a hard time getting widgets to work. The link above is broken. Would love to find a doc to follow. Thanks
This is my automation.yaml with a working widget.
- alias: Action iOS pause
initial_state: true
- platform: event
event_type: ios.action_fired
event_data:
actionName: 'Pause'
- service: scene.turn_on
entity_id: scene.pause
- service: media_player.media_pause
entity_id: all
In your app under “actions” you add a new one. “name” and “text” is called “Pause”
One of them actually doesn´t have to get this name but I can´t remember which one
Thank you. I was using mobile_app.action_fired instead of ios.action_fired. Do you only need the automation and the settings on the apple device? Nothing under ios: ?
I think one of the few remaining uses of “ios.” instead of “mobile_app.” is the widget part.
No the ios: part of the configuration.yaml is for actionable notifications.
https://companion.home-assistant.io/en/notifications/actionable
I get that the link doesn’t exist
Thanks! Do you know a link or helpful document or forum that talks about how to setup a complication?
Has anyone tried using multiple widgets? Using one is working great but when I’m using 2 different ones both are triggerd when one is pushed.
i’m having the same issue. I have 3 actions all different action names but everytime i trigger any of them, they all get triggered.
I assume this is solved now but for anyone finding this the reply above will also cover kasarap’s problemproblem. You’re only triggering you automation on ios.action_fired
not including the actionName
