Todo list as a trigger
So I cant get my head around todo.
I cant find to do as a trigger in an automation, and I’m aware you can now set due dates and times in the ui under the todo section.
Currently I’m still using local calendar which allows me to select the calendar name as a trigger the event message as a condition, so it doesn’t matter what time I set or change in the calendar event it picks it up by using the message and it then notifies me as the action at the time specified in the calendar event.
Is it possible to do the same or similar using todo instead of calendar?
I thought I might be able to set a numeric state as the trigger but then I dont know how to specify which to do event to choose from in the condition, because I may change the time the todo events are at.
This would then be a recurring tasks in the todo for the relevant days.
Here’s a quick screenshot of my calendar which currently works how I want the todo to work Calendar - Album on Imgur
Is it even worth bothering trying to change it from calendar to todo if it works how I want it to?
