Toggle Button and Thermostat group
I created this button in lovelace using the UI editor:
entity: group.termostatos_estacionado
hold_action:
  action: none
tap_action:
  action: toggle
type: entity-button
and I grouped in groups.yaml all my thermostats like this:
  termostatos_estacionado:
    name: Termostatos Estacionado
    entities:
      - climate.Estacionado_Anafe_H
      - climate.Estacionado_Hel_T
      - climate.Estacionado_Hel_H
      - climate.Estacionado_Ventilador_H
When I toggle the button for the first time it turns off all of the thermostats at once, then I toggle again and they are all on.
BUT
If I press the button again it doesn’t toggle back to off, the only operation it executes is on
BUT2
If I manually turn off any thermostat in lovelace and press the button again, the one I turned off turns on
Am I missing something here?
Adding:
if instead of trying to switch a group of thermostats I switch just one of them using the same reconfigured button it turns off and on as expected, not just the first time.
the toggle button for a group of thermostats still doesn’t work in 0.89
Have you solved the issue? I have the same problem.
