Hi all,
I really need Toggle button. Just to tap on, press on . When is pressed… event is fire, and when is release new event.
I think, it isn’t that hard to implement such button.
So, Please and Thank You.
Hi all,
Maybe you can do what you want with a script?
For Example I have a Script that, if activated, turns on the Nightlicht “Nachtlicht” for 5 minutes and then turns it automatically off. Just by pushing the Activate “button” in the frontend.
Input booleans are meant to be a button of sort. Have your automation monitor its status and if you want it off afterward just have your automation turn it off as the last step.
