Toggle CS pin to control multiple displays with a single display instance
Hi, I am working to make the Button+ in ESPHome. The Button+ knows multiple configurations with in the max 7 displays, 6 of them are the same type.
My problem is that is if I define 6 displays, I run in to ram problems the device does not have PSRAM so this is not an option… So I discussed this problem with the owner and he suggested to update the displays 1 by 1 by cycling through the CS pins. Like this:
  - id: cs_pin_bar_left
    platform: gpio
    pin:
      mcp23xxx: base_J3
      number: 5
      mode:
        output: true
      inverted: true
  - id: cs_pin_bar_right
    platform: gpio
    pin:
      mcp23xxx: base_J3
      number: 1
      mode:
        output: true
      inverted: false
display:
  - id: bar_display
    platform: ili9xxx
    model: ST7735
    color_order: bgr
    update_interval: never
    dc_pin:
      number: GPIO37
      allow_other_uses: true
    invert_colors: false
    show_test_card: false
    dimensions:
      height: 160
      width: 80
      offset_width: 24
script:
  - id: update_bar1_right
    then:
      - lambda: |-
          id(cs_pin_bar_left).turn_on();
          id(cs_pin_bar_right).turn_off();
          id(bar_display).fill(id(orange));
          id(bar_display).update();
          delay(10);
          id(cs_pin_bar_right).turn_on();
For some reason if I execute the update_bar1_script the display stays black. I asumed the we have a timing issue, so I am trying to use the set_cs_pin() method form the ili9xxx display component something like this below:
I am not an C++ expert, but by searching the web, this is where I landed ;). It is giving me a hard time…
  - id: update_bar_left
    then:
      - lambda: |-
          auto pin = esphome::mcp23xxx_base::MCP23XXXGPIOPin();
          pin.set_parent(base_J3);
          pin.pin_mode(esphome::gpio::Flags::FLAG_OUTPUT);
          pin.setup();
          esphome::GPIOPin* newpin = pin;
          id(bar_display).set_cs_pin(newpin);
But I have the feeling that the GPIOPin class seems not to be meant to be used on this level…
Any suggestions?
Thanks in advanced
