Toggle Lights & Scene On/Off via 1 button
Hi all.
I’m trying to use one light switch button to turn on my lights and set a scene; but also that same button when pressed will turn off the lights. My config below.
A) Currently this does not work, it keeps firing the same scene on and doesn’t turn off the lights.
B) If I remove the scene and leave them as toggle, then if I manually turn off one of those lights via Lovelace, the lights alternate toggle on and off because one of them was off.
How can I use toggle on/off with a pre-set scene via 1 button? I could do this with Samsung Smartthings, but struggling to understand how to do it in Home Assisant.
