Toggle not updating status
Hi Guys. So i have two input boolean toggle buttons. One to switch everything off when i go to bed and then one that switches in a select few devices in the morning. Now both buttons work and they turn off and on everything i want. However…
As you can see when the Good-Bye toggle is selected it turns everything off and the blue toggle is visible to show its been selected.
However when the Good-Morning toggle is run the Scene turns the Good-Bye toggle to off and then turns on some devices. However the Good-Morning toggle never shows blue that its been switched on. If i press it again it turns blue. Any ideas?
