I wanted to be able to toggle the blacklist function of Unbound in Opnsense from Home Assistant. The reason is simple: TVNow (a German TV streaming service) doesn’t work with my blacklists and I still haven’t figured out what all to whitelist for it to work. Logging into my OpnSense takes longer than simply clicking a switch in Home Assistant. I wanted to use the Restful Switch, but for the state I have to use GET and for changing the state I have to use POST with different URLs. I didn’t work for me, but maybe somebody can help me out there.
The button:
It toggles the blacklist function on of of.
My configuration:
switch:
switches:
unbound:
friendly_name: 'Unbound'
value_template: "{{ is_state('sensor.unbound_status', '1') }}"
turn_on:
service: rest_command.enable_unbound
turn_off:
service: rest_command.disable_unbound
rest_command:
enable_unbound:
url: https://router/api/unbound/settings/set
method: post
content_type: 'application/json; charset=utf-8'
username: 'key'
password: 'secret'
payload: '{"unbound":{"dnsbl":{"enabled":"1"}}}'
disable_unbound:
method: post
username: 'key'
password: 'secret'
payload: '{"unbound":{"dnsbl":{"enabled":"0"}}}'
- platform: rest
resource: https://router/api/unbound/overview/isBlockListEnabled
value_template: '{{ value_json.dnsbl.enabled }}'
username: 'key'
password: 'secret'
authentication: basic
Pressing the button immediately turns the black list on or of, but it takes a second for the sensor to register the new state
