Toggle switch for WLED playlists
Goal: have a toggle button on ha dashboard that will toggle my custom led overhead lights on and off.
What I have done: I have custom WLED playlists for on and off transitions (they’re awesome). I have also setup the restful calls in home assistant that I can call from the developer options.
The bottom line: I would like a button on the dashboard that looks like a lightbulb, and will toggle my on playlist, and my off playlist when pressed.
The issue I’m having: I don’t know how to make this button on the HA dashboard.
Any advice? I’m a web developer so I’m not afraid of writing custom code if needed.
Add a button:
Give it the icon you want and the tap action to call your restful command.
Thank you for the reply. I have a button that executes the turn on api call. The next issue I’m having is how do I make that button call the turn OFF api call when I press it again? I’d also like to have state on the button to indicate on or off.
Use an input boolean and get that to trigger automations.
If it’s ON run the “turn on” automation. If it’s OFF run the “turn off” automation.
What you want now is best done with a template light:
Don’t be bewildered by the multitude of options. They are almost all optional. All you need are the actrions for turn_on and turn_off. If you have state feedback from the light you can add a value_template as well. Otherwise it will work in optimistic mode and assume that the commands you sent from home assistant actually got there and changed the light. e.g.
light:
    lights:
      overhead_lights:
        friendly_name: "Overhead Lights"
        turn_on:
          service: # your 'on' rest command here
        turn_off:
          service: # your 'off' rest command here
        value_template: "{{ a template that returns 'on' or 'off' from your light }}" # optional
Restart Home Assistant.
You can then use this new light entity in an entity card (or any other card) in your frontend:
Thanks tom_I. The only issue I’m having now is the toggle switch can’t find the current state of my lights. When making the rest call, the device only returns success: true. So now my light button just keeps turning them on over and over. I’m a little foggy on the “value_template.” I think this is where I can get the lights current state. Any advice?
Maybe a restful switch instead of the rest commands?
Then use the “Switch as X” integration to turn it into a light.
Hey how have you created custom playlist for your wled?
