Hi, I have next configuration and I can’t enable a toggle switch (not momentary).
substitutions:
devicename: "bedroom-light"
friendly_name: "Bedroom Light"
channel_1: First Light
channel_2: Second Light
max_power: "2000.0"
max_temp: "70.0"
esphome:
platform: ESP8266
board: esp01_1m
comment: "Shelly 2.5 Bedroom"
# WiFi connection
wifi:
ssid: !secret wifi_ssid
fast_connect: on
power_save_mode: HIGH # for ESP8266 LOW/HIGH are mixed up, esphome/issues/issues/1532
#Old device name
# use_address: shelly25-bedroom.local
manual_ip:
static_ip: 192.168.5.174
gateway: 192.168.5.1
subnet: 255.255.255.0
ap:
ssid: "${friendly_name} Hotspot"
password: !secret hotspot_password
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
# Enable over-the-air updates
ota:
# Enable Web server
web_server:
port: 80
auth:
username: !secret web_server_username
password: !secret web_server_password
time:
- platform: homeassistant
i2c:
sda: GPIO12
scl: GPIO14
- platform: ade7953
irq_pin: GPIO16 # Prevent overheating by setting this
voltage:
# On the Shelly 2.5 channels are mixed ch1=B ch2=A
current_a:
internal: true
current_b:
internal: true
active_power_a:
filters:
- calibrate_linear:
- 0.0 -> 0.0
- 105 -> 12.3
- lambda: if (x < 2) return 0; else return (x);
on_value_range:
- above: ${max_power}
then:
- switch.turn_off: shelly_relay_2
- homeassistant.service:
service: persistent_notification.create
title: Message from ${friendly_name}
data_template:
message: Switch turned off because power exceeded ${max_power}W
active_power_b:
filters:
- calibrate_linear:
- 0.0 -> 0.0
- -42 -> 5.1
on_value_range:
then:
- switch.turn_off: shelly_relay_1
data_template:
update_interval: 30s
- platform: total_daily_energy
power_id: power_channel_1
filters:
- multiply: 0.001
unit_of_measurement: kWh
power_id: power_channel_2
filters:
# Multiplication factor from W to kWh is 0.001
- multiply: 0.001
# NTC Temperature
- platform: ntc
sensor: temp_resistance_reading
name: ${friendly_name} Temperature
unit_of_measurement: "°C"
accuracy_decimals: 1
icon: "mdi:thermometer"
calibration:
b_constant: 3350
reference_resistance: 10kOhm
reference_temperature: 298.15K
on_value_range:
- above: ${max_temp}
then:
data_template:
message: Switch turned off because temperature exceeded ${max_temp}°C
- platform: resistance
sensor: temp_analog_reading
configuration: DOWNSTREAM
resistor: 32kOhm
- platform: adc
pin: A0
status_led:
pin:
number: GPIO0
inverted: yes
switch:
- platform: gpio
pin: GPIO4
icon: "mdi:electric-switch"
restore_mode: RESTORE_DEFAULT_OFF
- platform: gpio
pin: GPIO15
binary_sensor:
- platform: gpio
pin:
number: GPIO13
on_state:
then:
- switch.toggle: shelly_relay_1
filters:
- delayed_on_off: 5ms
- platform: gpio
pin:
number: GPIO5
on_state:
then:
- switch.toggle: shelly_relay_2
Like in this screenshot from original shelly settings:
I tried this but if I press on phisical switch nothing happen
- platform: gpio
pin:
number: GPIO5
mode: INPUT_PULLUP
inverted: True
on_state:
then:
