Toggling LG TV with webOS
I’m trying to create a script that will toggle my LG TV power state.
So far this is what I configured:
configuration.yaml:
# swtich for WOL LG TV
switch:
  platform: wake_on_lan
  mac: !secret lg_mac_address
# LG smart TV
webostv:
  host: !secret lg_host
  name: Living Room TV
  #other settings
  turn_on_action:
    service: switch.turn_on
    entity_id: switch.lg
  customize:
    sources:
      - Mi Box
      - youtube
      - netflix
      - PS4
      - makoTV
script.yaml:
lg_toggle_power:
  sequence:
    - service: switch.toggle
      data_template:
But it only powers the TV on and not powering it off.
The goal is to create one button to do both on and off functions. Something like this:
 denon_toggle_power:
  alias: "toggle power denon"
  sequence:
    - service: media_player.toggle
      data_template:
        entity_id: media_player.denon_2
Thanks in advance!
Make a template switch.
  switches:
        lg_tv:
            friendly_name: LG TV
            value_template: "{{ is_state('media_player.living_room_tv', 'on') }}"
            turn_on:
              service: media_player.turn_on
                  entity_id: media_player.living_room_tv
            turn_off:
              service: media_player.turn_off
I think this shouldn’t be in the esphome section.
Moved
thanks for the answer.
once I define this template, how do I use it?
Can’t you just use media_player.toggle ? Don’t need a switch ?
Youre trying to toggle your wake_on_lan switch
Your script just needs to be:
lg_toggle_power:
  sequence:
You can also remove the WOL switch and add it directly to the webos config, make sure to add the broadcast address that suits you LAN (not the IP of your TV)
webostv:
  turn_on_action:
    service: wake_on_lan.send_magic_packet
      "mac": !secret lg_mac_address
      "broadcast_address": "192.168.1.255"
      "broadcast_port": 7
  customize:
    sources:
      - Mi Box
      - youtube
      - netflix
      - PS4
      - makoTV
You were correct, I used the media_player service and it worked.
THANKS!
Hi all, complete novice here. Trying to make my first script. I’m trying this one however am getting an error when attempting to save.
I’ve tried removing the first line and then I get the following error:
Error executing script. Invalid data for call_service at pos 2: required key not provided @ data[‘command’]
Might need an alias ?
lg_toggle_power:
  alias: LG Toggle Power
  sequence:
Same error when attempting to save the script.
Message malformed: extra keys not allowed @ data[‘lg_toggle_power’]
I must be doing something really basic (and obvious) wrong. Is it where I’m editing the script?
Doing it from the UI, Configuration, Scripts, New Script, Edit in YAML, Save Script.
alias: lg_tv
sequence:
mode: single
or
alias: lg_tv
sequence:
mode: single
and when you want to call the service directly from lovelace (without a script), for example from a button
it would be
tap_action:
  action: call-service
  service_data:
Thanks everyone. Issue ended up being related to a corrupt configuration. scripts weren’t saving correctly.
Hi @Holdestmade
Thx for this! Works like a charm!
Now i want to put it a set further
I want 3 scripts:
  • turning that tv on/off but starting at source: tvvlaanderen (its an app)
  • turning that tv on/off starting at source netlix
  • turning that tv on/off + starting my nvidia shield on/off
Is that possible with webos or not?
Thx for your help
Yes that should be possible
For the first 2, in your scripts, first turn on the TV, then you’ll probably need a delay to wait for the TV to power up and be ready, then call the media_player.play_media service as described here:
For the 3rd, do the same but just turn on your shield
ok but what do i do then with media_player.play_media
media_content_id: “netflix”
media_content_type: “source”
Something like that?
Just tried this, this works:
service: media_player.select_source
  entity_id: media_player.monitor
  source: Netflix
Make sure your sources are setup and in the source_list (viewable in dev tools states)
Cool thx !
One more question
Now it looks like this, the script
## Netflix aanzetten
netflix_aanzetten:
  alias: Netflix aanzetten
  icon: "mdi:netflix"
  sequence:
      entity_id: media_player.living_tv
    - delay: 00:00:02
    - service: media_player.select_source
        source: Netflix
Before i added the select source, i could use the script to turn on / off
How will that react now?
Cause i added the select source, or doesnt it do any harm?
If its state is off now, it will turn on and select source netflix
if its state is on now, it will turn off and select the source too ?
It should be OK, depending on whether the TV turns back on when the select source is called ?
Problem is if you run this and netflix is playing, then you run another script to watch another source, it will turn the TV off
You may need a turn and and off script.
You could either have separate buttons to call them or you could set up a template switch to run the on and off actions
Thats true.
When tv is on, and i run script to watch netflix it will turn off instead of switching sources
However, if the tv is on (source tv or netflix) we will probablhy dont use the script to change sources, once the tv is on
i’m not sure yet
For now i’m still struggling with the source he doesnt select, propably the delay is too short
So how would you do it? A turn on/off sciprt, or having separate buttons or with a template switch
Whats the best route to go
Turning on/off we will mostly use google to call the script,
