New Features
By-pass Options - This allows you to add a by-pass to the automation. you have 3 by-pass options.
- Enable the By-pass - Turn fan ON
- Enable the By-pass - Turn fan OFF
- Enable the By-pass - Keep the fan current state
What can this now do?
- Allow manual control of you fan.
- Allow you to create a run on timer for the fan.
- Allow you to use this blueprint with my other blueprints.
Example on how to use it with my
Bathroom Humidity Exhaust Fan
If you are using my “Bathroom Humidity Exhaust Fan” blueprint and you would like to give priority to it and disable this automation to then return back to normal when the “Bathroom Humidity Exhaust Fan” blueprint finishes then you would do the following.
First create a toggle helper and enter it into “Enable the By-pass - Turn fan ON” or “Enable the By-pass - Keep the fan current state” as shown below.
Then in my “Bathroom Humidity Exhaust Fan” blueprint you would enter this same helper into the “Fan Switch” as shown below.
If you are using low speed in my “Bathroom Humidity Exhaust Fan” blueprint you would enter this same helper into the “Fan Switch” & “Low Speed Switch” as shown below.
That is it your done
If you like this blueprint? Consider hitting the
button in the top post
If you like my blueprints, and would like to show your support or just say thank you? Click Here
Enjoy
Blacky
