The Tomato Component for Home assistant states that it only tracks wireless clients. I suggest this component be updated to use arplist instead of wldev as arplist will track both wireless and wired clients.
I’m new to this… Is there a way I can suggest the needed changes to the code as I’ve done it using a custom component and figured the main component should be updated as well…
I copied the tomato component over to a custom_components directory I created and then edited the python file to replace wldev with arplist is all I did.
All I did was take a look at the source code of the device list page for tomato… I figured… why not just use the arplist as that’ll catch connected devices wireless or wired.
Seems to work with the limited testing I’ve done. I had wired devices that have shown away for a while and they are now home since I tweaked the component file.
